Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By raino
    Closingracer's Avatar
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    Default When and where will T-Mobile use the 700mhz spectrum?
    As the title says plus which phones already have the required radios? I know my note 3 has a 700mhz but not sure which band. I hope my phone has it and it is in nyc so it can help me with signal issues in my house
    Sent from my SM-N900T
  2. #2
    Default Re: When and where will t-mobile use the 700mhz spectrum?
    IIRC, handsets were due Q4.
  3. #3
    Quote Originally Posted by raino View Post
    Correct.
    http://forums.androidcentral.com/android-central-lounge/2-note-3-lg-og-pro-got-my-g1-day-before-launch.html#post3
    The note 3 doesn't support tmobile 700MHz
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  4. #4
    Wonder when the next generation phones are coming out that support the 700 mhz spectrum and the refarmed 2G.
    So wasteful that I have to buy new phones not to keep up with the latest hardware processors/memory etc. but just to keep up with the ever-changing network requirements.
  5. #5
    A number of current tmobile phones currently support refarmed 2g already, though the network isn't up yet. As for 700 MHz, that should be in q4
  6. #6
    Quote Originally Posted by dpham00 View Post
    Any idea of the list of current phones? Nexus 5????
  7. #7
    Quote Originally Posted by Bigballer View Post
    Most recent phones should have the UMTS 1900 band. The Nexus 5 does. If there are others you're looking at, it wouldn't hurt to double check before buying.
    Bigballer likes this.
  8. Thread Author  Thread Author    #8
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    Meh the refarmed 2G is useless for me because I never had their 2G service in my house back when i was with T-mobile when they were dead last bringing out 3G ( had a Sidekick LX and blackberry peral before i left them)
  9. #9
    Quote Originally Posted by Closingracer View Post
    They could add or reconfigure towers. I used to get weak signal in my house, but Verizon added a new tower and my signal is much better
  10. Thread Author  Thread Author    #10
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    I still get no service. It is because the building walls are pretty thick. Also because if the higher frequencies t-mobile uses compared to AT&T and Verizon
  11. #11
    It depends on the building configuration and tower location.
    I connect to Verizon's aws network inside my office, which is 1700 /2100.
  12. Thread Author  Thread Author    #12
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    I know it's the frequency that's the issue with where I live
    Sent from my SM-P600 using Tapatalk
  13. #13
    What signal are you getting outside the building
  14. Thread Author  Thread Author    #14
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    Idk how to figure that but I know I'm getting full bars once I leave my building or stick my phone outside my window
  15. #15
    Install "advanced signal status"
  16. Thread Author  Thread Author    #16
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    Don't have root access (never felt the need to)
  17. #17
    Don't need root access to use the app. I don't have root myself.
  18. Thread Author  Thread Author    #18
    Banned
    Posts
    Global Posts
    4,803 Global Posts
    It says that you do
  19. #19
    It says that you do
    It needs root for certain parts, but not for the screen I posted
  20. #20
    It needs app for certain parts, but not for the screen I posted
    This.
    Sent from my T-Mobile Note 3 using AC Forums.
  1. Replies: 18
    Last Post: 02-25-2015, 11:12 PM
  2. Lost Pics from the Camera Folder
    By Cyrene in forum Verizon Samsung Galaxy S4
    Last Post: 04-11-2014, 09:47 PM
  3. Spring feeling when you tap the Galaxy S5?
    By atg284 in forum Samsung Galaxy S5
    Last Post: 04-11-2014, 09:15 PM
  4. Where are my favorites in IE?
    By deniese cobbins in forum Samsung Galaxy S5
    Last Post: 04-11-2014, 08:14 PM
  5. [LWP] Sputnik and Space Pioneers 3D
    By 1985Applications in forum Developer Spotlight
    Last Post: 04-11-2014, 08:02 PM
