1. Buck-eye's Avatar
    I am testing T-Mobile's network in my area on a LG G2. I have 4g while outdoors and driving around but 2g inside my house. Will being on 2g cause battery drain? Will it be searching for a 4g signal while on my WiFi network at home?
    06-12-2014 01:18 PM
  2. Almeuit's Avatar
    If you're on wifi you should be okay... But it may still look for a stronger signal unless there really is none to be had.
    Are you on a T-Mobile branded g2?
    Sent from my T-Mobile Note 3 using AC Forums.
    06-12-2014 03:29 PM
  3. Buck-eye's Avatar
    Yes, I am on a T-Mobile branded G2. Just wondering if I should ask for a Cel-Fi unit from them to keep my phone from wasting battery.
    06-14-2014 08:17 AM
  4. Almeuit's Avatar
    Try using the wifi calling feature on the phone. It'll shut the radio off and use the wifi as the cell signal.
    06-14-2014 08:53 AM
  1. New Way to Root possible? Check This Article on Cnet
    By Raymond Hubbard in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 06-13-2014, 09:50 AM
  2. Can't access files on computer
    By 4ringsa6 in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-12-2014, 05:13 PM
  3. Better internet reception on Note 3 versus Note 2 ?
    By Casey Cheung in forum Verizon Samsung Galaxy Note 3
    Last Post: 06-12-2014, 02:47 PM
  4. MetroPCS samsung S5 on tmobile network
    By epicness4G in forum Samsung Galaxy S5
    Last Post: 06-12-2014, 12:51 PM
  5. Help on Rooting or downgrading my At&t galaxy S4 4.4.2 KitKat
    By superhalder in forum Android 4.4 KitKat
    Last Post: 06-12-2014, 12:47 PM
