Results 1 to 7 of 7
    juicer731's Avatar
    Posts
    ROM
    Stock, Gtabcomb 3.3
    Default Nexus S Wifi Hotspot Not Working
    For some reason I can't get this to work. Whenever i try to use the hotspot feature on my Nexus S, it fails. I am able to turn the feature on and set up a password and all but then when i try to connect my tablet or ipod or anything to it, it says connected. So then on my connected device, i go into the browser or some other internet-needed application but it says not connected to the internet. I don't get it. In my status bar it shows wifi is clearly connected. Please help.
    Thanked by:
  2. #2
    rockigirl's Avatar
    Posts
    Global Posts
    1,218 Global Posts
    ROM
    AOKP with Franco
    Default Re: Nexus S Wifi Hotspot Not Working
    I'm having the exact same issue. Any answers would be great.
  3. #3
    Android Rookie's Avatar
    Posts
    ROM
    Rooted Captivate
    I am also having the same issue. I'm on Version 2.3.6 Build# GRK39F. Can someone please help. I thought this build # was the corrected build number that fixed the tethering issue with the initial roll out of 2.3.6 to the I9020A.
  4. #4
    Posts
    ROM
    Rooted Captivate
    I'm on Version 2.3.6 Build# GRK39F. Can someone please help. I thought this build # was the corrected build number that fixed the tethering issue with the initial roll out of 2.3.6 to the I9020A?
  5. #5
    kmbauer's Avatar
    Posts
    Global Posts
    157 Global Posts
    ROM
    Stock Jelly Bean
    FYI - This seems to still be the case with the factory image Android 4.1.1 (JRO03E)
    from
  6. #6
    Default
    I can tell you that WiFi hot spot worked on my nexus s with 4.0.4
    I was using it with my nexus 7 tablet
  7. #7
    My home wifi turns itself on and off at random since Jelly Bean. I have to go into settings, turn wifi off, let it load 3G, then turn on the wifi again. Painful.
