Results 1 to 7 of 7
    karoelle's Avatar
    Posts
    ROM
    ICS Stock I9023
    Default Problems after restoring from backup
    Hi all!
    I received the ICS ver. 4.0.3 OTA 6 days after I received the Google Nexus S in the middle of December, I let the update go on, but had as many other problems with power consumption. There was another strange problem with Maps/Navigation, best as I was driving along the road "the lady" began to read a text that sounds roughly like this:" http://www.w3.org/2001/"+ something more where the word livetstrę (tree of life) is included, it is running like that in endless loop until I stop navigation, language is Danish. This problem is still there after back to factory setting, maybe it was wrong to select restore the apps when I reset the phone? But is there anyone who understands/can explain what goes wrong with Maps/Navi "lady" hoping for help here/Is it phone or Andorid update that makes the problem?
    My Nexus S is EU model I9023 IML74K. Stock Android
    BTW. power consumption are much better now
    Sorry for my bad English
    Karoelle
  2. #2
    Cory Streater's Avatar
    Forums Emeritus
    Posts
    Global Posts
    13,813 Global Posts
    Default Re: Problems after restoring from backup
    That problem is definitely one I haven't heard of before, but you are correct that it is probably related to the restore feature. Particularly when upgrading to a new OS release. I would factory reset and start over.
    karoelle's Avatar
    Posts
    ROM
    ICS Stock I9023
    Thanks Cory!
    I will do a factory setting and be back when I know the outcome.
    Some people here sayes that the update has bug, the update vas stopped by Google,
    but my update came OTA and I am stuck with it.
    Karoelle
  4. #4
    SandyDoxy's Avatar
    Posts
    ROM
    Stock 2.3.4
    I'm not trying to be forum police or anything, but this section is for the AT&T Nexus S (9020a), which has not had an OTA ICS update (as far as I know).
    So most of the readers here do not have an OTA ICS update, and probably won't be your best resource for help with your problem. I would suggest that if you still have trouble after Cory's suggestion, you post in a forum more tailored for your flavor of Nexus S.
    On the bright side - we're all jealous of your ICS phone.
    karoelle's Avatar
    Posts
    ROM
    ICS Stock I9023
    Sandydoxi!
    I know I am on wrong forum, I am not shure Androidcentral have a Nexus S I9023 (EU forum)???
    But Androidcentral forum have a lot af Wise guys to help dudes like me
    Can you direct me to where I can post in Androidcentral, in advance Thank you.
    Karoelle
  6. #6
    SandyDoxy's Avatar
    Posts
    ROM
    Stock 2.3.4
    Maybe the T-Mobile Nexus S forum would be your best bet? That's a 9023 with GSM and I think they've had the ICS update.
    karoelle's Avatar
    Posts
    ROM
    ICS Stock I9023
    SandyDoxy!
    Thank you, I will try to use T-Mobile forum if/when I need help (I will fore sure)
    karoelle
