Re: Permanent brick? HELP!!!
Same thing happened to me... Stay calm, you can fix this...
Plug into your PC... It'll tell you "mass storage device not formatted"... Just format it (I downloaded SDFormatter to do this), and drag a rom onto it after it is done, then go through the flash method I posted on your other thread..
Can we not use cwm?? And no if you can acess the boot loader then your not totally bricked.
Sent from my HTC One X+ using Android Central Forums
Cwm isn't specific for our device... TWRP works best
Well damn that sucks!! I loved cwm on my inspire
I've used both in my time, and TWRP is definitely better after you get use to it
I agree TWRP is great. I tried to install CWM first and couldn't even get it to work, so I flashed twrp instead.
OP: Did you get this fixed?
