Results 1 to 6 of 6
    atomic_squid's Avatar
    Posts
    ROM
    CM 10.1 and AOKP 4.2 RP
    Default Reasonably major battery issue
    So. I flashed Nocturnal'd ROM, and I'm loving it. Except for when my battery runs low. Almost invariably upon reaching 8%, my phone forgets that numbers exist and jumps to 2 after like a minute. Any way to fix this?
    Sent from my One X rocking Nocturnal'd Dirty ROM 4.1
    Optimus G Pro, running CarbonROM 4.3!
  2. #2
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Default Re: Reasonably major battery issue
    I've never ran my battery that low... Hmm, are you on the newest update, 2.4c?
    Verizon Samsung Galaxy S4
    Rooted, HyperDrive Rom
    If I helped you out, hit the thanks button on this post!
  3. #3
    Yea I've had that happen to me. I just let it die and let it charge all the way back up. And If it's consistent boot to recovery, clear cache and dalvik cache. If that doesn't work I usually give up and flash cleanROM. Seems to be the only consistently smooth/stable ROM I've used.
    Sent from my HTC One XL using Android Central Forums
    Posts
    ROM
    No. Where do I get it? Do I have to reflash?
  5. #5
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    Go back to the forum, download the new update where you found the original, it should be labeled 2.4c... Flash it with flash GUI app, reboot to recovery and flash it in TWRP (first boot takes a little longer, if it boot loops once you are ok). You can dirty flash it-- don't have to wipe anything, but I usually wipe cache afterword anyhow...
    When you dirty flash (never do this when switching to different rom), all your apps and data for said apps should stay where they are. Just as a precaution, you SHOULD ALWAYS MAKE A BACK UP IN TWRP before flashing anything... Just in case anything goes wrong, you can always come back to where you were (just remember if something does happen/ boot looping nonstop/won't boot, you will need to fastboot the previous zip through your PC, then go into TWRP and restore your back up)
    EDIT: the reason I left the explanation for dirty flash is because that is how I always do it, only had one instance where it would not boot and had to plug into the PC and fastboot, then install... You can always just do a fresh install (wipe everything, then flash), some people do this with every update and just recover apps with titanium back up...
    Posts
    ROM
    It won't let me sign into my Google account...
    Never mind. I got it.
  1. Having major battery issues on 2 of my phones.
    By hanly2 in forum Samsung Galaxy S II Skyrocket
    Last Post: 12-05-2012, 08:35 PM
  2. Major Battery issues? Please help!
    By acer1096xxx in forum Sprint Galaxy S3
    Last Post: 09-19-2012, 02:20 AM
  3. Major Battery Issues Affter ICS Update
    By wezra in forum T-Mobile HTC Amaze 4G
    Last Post: 06-30-2012, 03:32 PM
  4. Weird Battery Issue?
    By jacob.downey in forum Google / HTC Nexus One
    Last Post: 01-30-2010, 03:24 PM
  5. I am having a Major (dealbreaker) issue with Android Market and the Pulse
    By pbrennan42 in forum General Help and How To
    Last Post: 01-06-2010, 10:38 AM
B
