Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By wesley20850
    Default Need help flashing kernel
    Noob here. Just flashed viper xl 3.2.1 and i just wanted to ask if anyone knew any good kernels out there. also it would be nice to include step by step instructions especially since im a noob. thanks a lot
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    13,821 Global Posts
    ROM
    Milestone 1/Lean Kernel
    Default Re: Need help flashing kernel
    Can't suggest kernels since its not my device but flashing is very simple.
    Boot into your custom recovery (ClockWorkMod or TWRP) and wipe cache partition & dalvik cache then flash the kernel using the same option to flash a ROM.
    NO DATA WIPE/RESET.
    Yes its that simple... Optional: You can make a backup within your recovery just in case of the unknown or you want to revert back to your old kernel/setup.
    Thanked by:
    alright sounds simple enough. so i should wipe the cache and dalvik cache before flashing but not after? and should i boot into recovery via command prompt?
  4. #4
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    With viper, use ElementalX 2.5... runs great.. Download it, hold power button till the power menu pops up, select reboot, then reboot to recovery.
    Once installed, wipe cache, then reboot system.
    HTC One X AT&T
    Viper XL 3.2.4: ROOTED 2.20 : Hboot 1.14 : S-OFF!
    Nexus 7 - Dirty Rootbox v2.0
    If I helped you out, hit the thanks button on this post!
    Thanked by:
    is there anything else that is important or its just that simple? and mind my asking but what are your settings?
  6. #6
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    It's that simple.. I have my tweaks with that kernel set at 1.7ghz, I/o scheduler set at fios
    HTC One X AT&T
    alright i flashed it just like you said and my phone bootlooped about 5 times but it seems stable now. is that normal or did i do something wrong?
  8. #8
    Bizzle69's Avatar
    Posts
    ROM
    ViperXL/Dirty Rom
    It happens sometimes... as long as you got booted up, your all good
    HTC One X AT&T
    Thanked by:
  9. #9
    Paul627g's Avatar
    Posts
    Global Posts
    13,821 Global Posts
    ROM
    Sorry I didn't respond quicker. The cache and dalvik wipe is only before you flash.
    So wipe, flash and reboot.
    Thanked by:
  10. Thread Author  Thread Author    #10
    thank you both. its been a day and no random reboots or crashes so its all good
    Paul627g and Bizzle69 like this.
  11. #11
    Paul627g's Avatar
    Posts
    Global Posts
    13,821 Global Posts
    ROM
    Awesome :-D
  1. i need help flashing a rom
    By ajskhan in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 06-23-2011, 11:42 PM
  2. need help flashing ROM
    By mikiemike in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 04-08-2011, 09:15 PM
  3. Need help putting kernels on phone
    By BigDroid in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 02-15-2011, 09:57 PM
  4. Rooted with 1-click, need help flashing recovery (newb)
    By FatDave in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 08-21-2010, 12:20 PM
  5. Need Help Flashing BB ROM
    By droidweasel in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 02-20-2010, 11:18 PM
