Results 1 to 24 of 24
    Default AT&T Samsung Galaxy Note 3 - Anyone having issues with Navigon on their Note3?
    I have nav in all my cars and don't really use it on my phone locally here in Colorado. I was in Austin the other week and used it for the first time. It kept freezing after a few minutes and lost gps. I resorted to Google maps which worked great;. When I got home here in Colorado I deleted it rebooted the phone and reinstalled it. I tried it out driving to the airport on Saturday and when I got on E470 I noticed the phone was locked up on I25 still.
  2. #2
    Default Re: AT&T Samsung Galaxy Note 3 - Anyone having issues with Navigon on their Note3?
    I have had issue with gps wouldn't;t lock on the signal both in google maps and waze. Since it's new and under warranty I called AT&T and they sent another one out and should be here this week hopefully it fixes gps issue
  3. #3
    I don't use the gps often but when I do I haven't had an issue yet. Although all I do use is Google maps. Maybe the note is so new the apps aren't made to work properly yet.
    Sent from my gameboy color
    Quote Originally Posted by eve6er69 View Post
    I am the same boat - I don't use it much either - but when Navigon failed I went to google maps and it worked. I suspect (and hope) it is just a firmware issue with Navigon that will get fixed.
  5. #5
    Vetdoctor's Avatar
    Posts
    Global Posts
    200 Global Posts
    Carrier
    Popcorn
    I use Google maps and Google navigation a lot. I have found it to be frustrating and undependable on the note 3. My last phone was HTC vivid and it worked fine in the same area.
  6. #6
    I just got a replacement for my note 3 and the gps has improved 100% haven't lost signal using nav yet
  7. #7
    Quote Originally Posted by nettech207 View Post
    I have noticed the same issue when I use waze. The gps signal will be fine one moment and on the fritz the next. Did they give you any hassle when you mentioned it to them and got a new one? Was it replaced under manufacturer warranty?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  8. #8
    no issues from att and yes it was replaced under manfacturer warranty. I told them I was having gps issue and they asked do i want one out next day for Additional $14 in next day air shipping or select 3 day for free choose free , anyways no problem with gps since switching
  9. #9
    I have purchased a note 3 from the Best Buy right when they came out specifically to use the GPS on the large screen which would be easier for me to see. I had GPS lost signal issues within the first 2 weeks. Best Buy replace the phone and within the next two weeks I continued having GPS lost signal from the second phone.
    I've done to factory reset and nothing seems to solve the problem. I purchased the Geek Squad warranty but what I bring the phone into Best Buy the GPS seems to work fine. This is an intermittent problem and I am told by the Geek Squad there's nothing they can do since they can reproduce the problem.
    I am very frustrated and don't know where to turn any help from anyone out there would be greatly appreciated.
  10. #10
    Quote Originally Posted by Mickey Goodman View Post
    No offensive I wouldn't trust the geek squad if my life depended on it. They are limited in what they can do and what they really know . I would call samsung since it is under warranty threw them. Like I mention since I got my replacement I haven't had any issues with gps and I use it on a daily basis
  11. #11
    Vetdoctor's Avatar
    Posts
    Global Posts
    200 Global Posts
    Carrier
    Popcorn
    I have started using GPS to go everywhere to test the connection. I find I loose GPS almost once every trip with the signal lost for 60 seconds to minutes. Even the 60 second loss is a problem if I have an upcoming turn. I'm going to try Samsung in the next few days when I get time. This isn't right.
  12. #12
    I have a similar problem. GPS signsl keeps getting lost and it's been a real problem. Samsung needs to resolve this issue.
  13. #13
    Quote Originally Posted by Sanju Khatri View Post
    Must be the AT&T version. I drove from Florida to New Jersey and kept GPS on the whole time.. Never lost me.
    Sent from my T-Mobile Note 3 using AC Forums.
  14. #14
    Sorry that I can't agree with your assessment of Geek Squad. I have always had good luck with them and they have typically gone out of their way to make things right.
    I hope your issue with gps gets resolved. I haven't had any issues with mine and I travel almost weekly.
  15. #15
    I've also been having issues with "GPS signal lost" message from the beginning. I only use Google Maps and it's usually in areas I would never expect which have good 4G LTE connectivity. The case is not the issue and it's usually near the door or on a mount. It's caused some serious issues for my wife and I when driving. Sometimes it will say it and return within 30 seconds, sometimes it will repeat "signal lost" 7 or 8 times and never connect, or sometimes it will say nothing and never reconnect. Even when I back out, clear the app, and hit resume or restart it will sometimes immediately say "GPS signal lost". It's complete ****, especially since my wife's S4 is absolutely rock solid.
  16. #16
    what i would do is having someone sitting in the back of the car with a video recorder (phone or cam) and go driving till the gps is lost then show geek squad the video
  17. #17
    Lightbulb Re: AT&T Samsung Galaxy Note 3 - Anyone having issues with Navigon on their Note3?
    Did anyone Contact SAMSUNG about the GPS Signal Lost Issue. I am thinking this is a Hardware Issue and Not a Software Issue.
  18. #18
    I had the same gps signal loss problem on my note 3 on Verizon. Happened regularly, along with other problems in Google maps, like stopping at a red light and the map think I'm going the other direction or float me to the intersecting road. I got a replacement phone after many attempts by Verizon to reset the device. The new phone is much better, but still not completely right. Once in a while, less frequently , same problems.
  19. #19
    My gps freezes on me a lot and starts sending my location back and forth across the map. I had to go and uninstall the updates and use the older version for it to work.
  20. #20
    Ok so I think I may have figured out when it happens. It seems to happen when the phone switches from LTE to 4G and vice versa. Seems like the phone doesn't know how to adjust properly and keep a gps signal. Anyone else have the same issue and or conclusion.
  21. #21
    Vetdoctor's Avatar
    Posts
    Global Posts
    200 Global Posts
    Carrier
    Popcorn
    Yes, Go to this thread on the ATT forums, sign in and click the "Me Too" button on the first post. Up to 57 signed in so far. You can look up the thread on the XDA forum. If you like you can root and install a simple fix . I'm still reluctant to root yet but my patience is wearing thin.
    mastaofdacat likes this.
  22. #22
    Yes! !!! Please! Register n click me too problem button! !!
    Sent from my Nexus 10 using Tapatalk
  23. #23
    Mr Bigs's Avatar
    Posts
    Global Posts
    715 Global Posts
    Yep the gps blows big time always losing location. It is an AT&T problem and I'm pretty damn sick of it never had this on Verizon.
  24. #24
    chuco35's Avatar
    Posts
    Global Posts
    82 Global Posts
    Quote Originally Posted by B0omSLanG View Post
    Same same with my Note3. I work around it by disabling and immediately enabling the GPS. Never had this problem with my BB, or my wife's iPhone. This continuous loss of GPS signal is a definite Samsung Note3 defect. Hopefully it will be patched by KitKat.
  1. Replies: 10
    Last Post: 01-24-2014, 04:16 PM
  2. Problems with camera and email attachments after 4.4 KitKat update.
    By jackdps in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-04-2013, 05:38 PM
  3. Galaxy Note 2 doesnt recognize any SIM card
    By peanuthater in forum Introductions
    Last Post: 11-26-2013, 10:38 PM
  4. Home screen issue
    By adamspt2 in forum Android 4.4 KitKat
    Last Post: 11-26-2013, 10:11 PM
  5. Replies: 0
    Last Post: 11-26-2013, 09:30 PM
