1. waynezo's Avatar
    When using the Samsung 2.1 amp charger does it matter if you use the samsung usb 3.0 or a regular micro usb cable for charging speed?
    Has any one found any good deals on car or wall chargers?
    12-07-2013 09:45 AM
  2. nettech207's Avatar
    Don't take this as fact I heard that as far as charging the usb 3 has no added effect over usb2 micro the benifit of the added usb 3 was for file trasnfering again it is what I heard I haven't seen any facts on either ways
    waynezo likes this.
    12-07-2013 01:20 PM
  3. Paravoz's Avatar
    it will only charge faster than USB2.0(500mah) if you connect it to your pc USB 3.0 port (900mah). Though, there is no effect with wall charging which is still the fastest way
    waynezo likes this.
    12-07-2013 03:41 PM
  4. waynezo's Avatar
    yes but what about with the 2.1 amp wall charger
    12-07-2013 04:08 PM
  5. Paravoz's Avatar
    its just gonna charge at 2.1 amps doesn't matter if its USB 3.0 or 2.0 there will be no difference if its through the wall charger
    waynezo likes this.
    12-08-2013 12:41 AM
  6. waynezo's Avatar
    OK Great! Now I don't have to buy new charging cables
    12-08-2013 05:59 AM
  1. DLNA for Dummies
    By Barry Adler in forum Motorola Droid MAXX
    Last Post: 12-09-2013, 02:55 PM
  2. Prepaid plan for N5 in So Cal?
    By dirtyjudo in forum Google Nexus 5
    Last Post: 12-07-2013, 09:43 AM
  3. What is other alternative for Speedtest.net?
    By naflush in forum Samsung Galaxy Grand
    Last Post: 12-07-2013, 09:05 AM
