Results 1 to 2 of 2
    Ronin12's Avatar
    Posts
    Global Posts
    3 Global Posts
    Default Disable power button when locked
    Hey guys!
    Love my note 3. My only grief is sometimes, while in my pocket, the phone will restart due to me inadvertently pressing the power button when bending down. Is there a way to not allow the phone to power off or restart while it's locked?
    Thanks.
  2. #2
    Default Re: Disable power button when locked
    I believe there's an app for that (no pun intended), but if I recall correctly you'll need root, as the power button is the ONLY button that's 'hard-wired' in the system to wake up your device; you can disable volume and home buttons with other apps easily, but for this, you'll need root and you should do so at your own risk, this is a very crucial 'trigger'.
  1. Setting a lock screen photo
    By Shaun Osborn in forum Samsung Galaxy S3 I9300
    Last Post: 04-03-2014, 11:03 AM
  2. Can't change lock screen wallpaper :(
    By luna_r in forum Sony Xperia Series
    Last Post: 12-16-2013, 10:35 AM
  3. Can I disable System UI Notifications?
    By Airpilot1 in forum Samsung Galaxy S4
    Last Post: 12-12-2013, 01:16 PM
  4. Screen doesn't wake when text messages come through?!?!?
    By shaneontherocks in forum Sprint Samsung Galaxy S4
    Last Post: 12-10-2013, 10:31 PM
  5. Replies: 1
    Last Post: 12-10-2013, 08:26 PM
B
