Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By UJ95x
  • 1 Post By Sonnydigs
    Default Help an Android noob
    I've had this note 3 for about a week. Every 5 minutes or so it makes a notification sound that I can't figure out. How can I disable this? What is it?
  2. #2
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    Slim Kat 4.4.2 Build 3
    Default Re: Help an Android noob
    Welcome to Android Central
    Could you post a screenshot of the notification when you get it?
    Everything in this post is 100% accurate...I think
    R.I.P. Motorola...and what could have been the best smartphone line ever
    Thanks. I don't get a notification in the bar. But it does make the sound I set for notifications
  4. #4
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    Weird...so it just makes the sounds, but there is no notification of any sort? No texts, e-mails, etc.?
    Exactly
    When I first got it I was using the stock text message app. Then I found out about group texting and got hangouts. Now I noticed that my text messages come into three different places. The stock app, hangouts and AT&T messages. Could there be an issue with the 3 interacting with each other? Can any of these be deleted to help the problem? What would happen if I remove the stock app? Would I be able to get it back if I needed/wanted it?
  7. #7
    Golfdriver97's Avatar
    Posts
    Global Posts
    13,810 Global Posts
    ROM
    Stock Moto X
    Is everyone you have in contacts in Hangouts?
    From a Sprint Moto X using the AC Forums app.
    Devices: Current: Nexus 5, Moto X, Galaxy Tab 2 (7.0); Retired: Galaxy S2 (Epic 4G Touch); Traded: Galaxy S3
    When I let go of what I am, I become what I might be - Lao Tzu
    Community Guidelines and also here
  8. Thread Author  Thread Author    #8
    I didn't go through one by one. But after a quick scroll through it looks like they are
  9. #9
    Quote Originally Posted by Matt Delacoma View Post
    Disable the stock texting app and also the AT&T app if it allows it. I use Handcent and completely disabled the stock texting app. See if that works.
    Samsung Galaxy Note 3 using Tapatalk
    Thanked by:
    UJ95x
  10. Thread Author  Thread Author    #10
    Rather than delete, I tried turning off. AT&T is turned off. Not sure what happened with the stock app. It's now gone from everywhere I look and can't find it. And the annoying notification sound is now worse....it does a double sound now.
    I was interested in the note 2 but stayed away after hearing bad things about android. Finally decided to try the note 3. The bells and whistles on android/Samsung enticed me. But all the bad stuff I read and heard about android is now being experienced first hand. Why does everything have to be so complicated and frustrating with this OS?
  11. #11
    UJ95x's Avatar
    Posts
    Global Posts
    5,535 Global Posts
    ROM
    I assure you this isn't a regular thing. I have never had any of the issues a lot of people seem to complain about; most of the time, it's an app someone downloads. This is not to blame on the OS
    Thanked by:
    rvhs03 likes this.
  12. #12
    rvhs03's Avatar
    Posts
    Global Posts
    22 Global Posts
    Quote Originally Posted by UJ95x View Post
    I absolutely agree. I've had nothing but Iphones and got the Note 3 a couple days after release. I read ALOT of these forums and occasionally I will have a bug mentioned here but most of the time its smooth sailing. From my brief experience I would also venture to say it is usually an app causing issues. I absolutely love this phone and nothing will change my mind!
  13. #13
    possumdel's Avatar
    Posts
    Global Posts
    16 Global Posts
    I have other issues with Android not mentioned here. I'm 6 days in with this phone and it's driving me crazy. I don't understand why sometimes an action prompts a notification sound and sometimes it doesn't. Sometimes when I try the dual screen, the page I want opens and sometimes it doesn't. Sometimes when I already have dual screen open and try to switch one of the screens to a different page, it switches the wrong screen. It's hard to explain what I'm experiencing, but there are times when what I want to do either does something different or not at all. Like touching an icon or link. You could say that the issue is with the apps and not the OS. But the apps are created FOR the OS, so it kinda is ya know? I feel like a person needs to have computer knowledge in order to make an Android phone work for them. I'm trying to figure things out and hang on to this phone. There are some things that ARE working great and I love it. But to be completely honest, if I can't get things ironed out by this weekend then I plan to eat the expenses incurred to date and go back to my Windows Phone. It doesn't have all the bells and whistles, but it doesn't have all the issues either.
  14. #14
    possumdel's Avatar
    Posts
    Global Posts
    16 Global Posts
    So apparently I already had an account under the username possumdel. I didn't realize/remember that and signed up to post. Matt Delacoma and possumdel are one and the same, I assure you
  15. #15
    Dual screen isn't compatible with all apps...
    I came from many yrs of iPhone and yes there is a learning curve but I love the the Note3..
    Hang in there it will get easier..
    This is the place to get the answers you need..
    Good luck..
    Sonny
    Golfdriver97 likes this.
  1. s3 gt-i9305 help help wiped everything
    By Dave Winfield in forum Samsung Galaxy S3 I9300
    Last Post: 12-22-2013, 03:10 PM
  2. Please help. New Goophone i5C has no icons...just black screen with Chinese text
    By oldbutreliable in forum General News & Discussion
    Last Post: 12-20-2013, 06:25 AM
  3. Please help me understand this
    By zazazi in forum Samsung Galaxy S4
    Last Post: 12-19-2013, 10:16 AM
  4. HELP with my Order!
    By AndroidDario in forum Google Nexus 5
    Last Post: 12-19-2013, 04:31 AM
  5. Make Android device with NO SAFE MODE
    By Mohammed Taheer in forum Introductions
    Last Post: 12-18-2013, 03:31 PM
B
