"Android OS" killing my battery...
eugchen
77
today at work, my battery started at 100% at 8am and drained to 30% by 4pm with minimal usage. GPS, Wifi, instant messaging were all off. Screen is turned low, and auto is checked. Location services are all unchecked. Power Saving Mode is turned on.
I go to settings and see that 96% of the culprit is "Android OS". what is this, and what else can i check to see what is causing this?
thanks
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,517
4,659
113
Android OS encompasses many of the core functions of the operating system, so it can be difficult to say which process was specifically causing your drain. You could try installing GSam Battery Monitor or something similar to get a more detailed breakdown.
eugchen
77
Re: "Android OS" killing my battery...
well i ran Gsam yesterday, and it turns out the culprit is something called Kernel OS..what is this? do i need to replace the kernel?
- - - Updated - - -
Go to settings/location services/then unclick use wireless networks. (instant fix)
yes, those were already unchecked...
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,517
4,659
113
I wouldn't advise it. Try rebooting first. Then try a cache partition wipe as mentioned above, if the reboot doesn't help.
