Page 1 of 3 123 LastLast
Results 1 to 25 of 61
Like Tree4Likes
    dave0813's Avatar
    Posts
    Global Posts
    27 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default AT&T Note 3: GPS Signal Lost
    Has anyone have the problem with your GPS signal being lost? I have the most recent update but I cannot go longer the 7 minutes without the dreaded "GPS Signal is Lost". And I have tried several areas and I still have the same problem.
    Any comments or suggestions or links to a common fix?
    Thanks in advance
  2. #2
    Kelly Burby's Avatar
    Banned
    Posts
    Global Posts
    706 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: GPS Signal Lost
    Quote Originally Posted by dave0813 View Post
    Thanks in advance
    Make sure that you have working data connection because GPS needs an active data connection, from my point of view the problem with you is you're data connection might not be working and because of that GPS signal gets lost. And if you are sure that you always have an active data connection than i think that its because of the recent update you have received.
  3. #3
    bigjim71's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have had the same problem myself. Each time I have used the gps I would loose the signal after only a few minutes each time. I would have turn gps off and on again every few minute, very annoying . I had a good strong data signal as well. A lot of other people in the general note 3 forum are complaining about this issue as well and they all are on ATT. Could it a carrier issue, or could it be software? Who knows, Im sure well never find out cause one will keep pointing the finger at the other.
  4. #4
    ernestojtorres's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Same issue with me in Florida. I use Waze to navigate and my GPS comes in and out. My previous cell phone was an iPhone 4 with At&t as my carrier and never lost gps signal. Is frustrating, thinking of buying a garmin to use while I travel
  5. #5
    jabo75's Avatar
    Posts
    Global Posts
    53 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Kelly Burby View Post
    This is absolutely false. The GPS chip in this phone works completely independent of the cellular data radio. If you don't believe me, put the phone in airplane mode then make sure the wifi and GPS are on.
    The loss of GPS signal is a know issue with the AT&T flavor of this phone. I had the same issue and contacted AT&T. They admitted that there is an issue with the GPS. They sent me a replacement. I have had it for a few days. So far the replacement seems to be working.
  6. #6
    Halen16's Avatar
    Posts
    Global Posts
    35 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes I have the same problem
  7. #7
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: AT&T Note 3: GPS Signal Lost
    This is a known issue. I had mine replaced by AT&T a month ago and the tech support guy told me that I was the third call that 1 day for the same issue. He said it had been happening frequently.
    I haven't had problems with GPS on my replacement device, but I am now on my second replacement due to issues with the first one. Now this one seems to have battery issues. I'm getting a bit frustrated.
  8. #8
    Rukbat's Avatar
    Posts
    Global Posts
    22,834 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    I've heard a rumor that AT&T is coming out with an update to fix the problem (which is a software problem) "very soon".
    Sonnydigs likes this.
  9. #9
    jonlien's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rukbat View Post
    I hope you are right. This is a very annoying problem since I use my GPS a lot.
  10. #10
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So the phone has been on the market for 4 months and the GPS is faulty at best and won't work at worst. Great AT&T, why is it they seem to have GPS issues the most?
  11. #11
    usafsp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    For the first time, yesterday, it happened to me. I've had the phone for quite some time and it's always worked using Google Maps. But yesterday, I was 5 minutes into my travel and got the dreaded message.
  12. #12
    Chuckcell's Avatar
    Posts
    Global Posts
    249 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I flew to Omaha and got a rental car Thrifty - no GPS! I relied on my Note3 and it lost the GPS signal repeatedly. Just glad I wasn't in a tighter situation!
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  13. #13
    Mr. Blick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just drove from Oklahoma City to Pensacola, FL over the last 2 days. Every single time data switched to 4g from LTE and back to LTE, GPS signal lost message came up. Happens with Google maps and Waze. Turning GPS off/on fixed it, but not safe to do this all the time.
    Very very unhappy. Will call AT&T after I get back home.
    Sent from my Nexus 7 using Tapatalk
  14. #14
    aegould's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I, too, made and 80 mile trip this past weekend and had the same thing happen to me. Was using my navigation software and noted that the GPS dropped EVERY time the signal went from 4G to LTE, or vice versa. It was maddening.... Am going to an iPhone 5s instead....at least Apple's chips/hardware/OS will maintain the GPS...no matter what band of cell service the device is on.....
  15. #15
    reelon's Avatar
    Posts
    Global Posts
    240 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock as can be
    Wow this sound bad. I just finished calling with Att support because my Moto x kept dropping calls every time, they didn't have any moto x available at the moment so they are going to send me a note 3. I really do use the gps alot. I guess I will have to return the note 3 if I come up with this issue.
  16. #16
    Mr. Blick's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Called AT&T today. Basically told me to back everything up and factory reset it. Also made mention of Kit Kat by end of the month. Kind of bummed about the rote answer but it was what I expected.
    I'll probably set aside some time this weekend and try it out.
  17. #17
    usafsp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by usafsp View Post
    Thought maybe Google Maps was the issue. Downloaded and used Waze and had the same problem. On again, off again dropping of the signals. Haven't made any phone calls yet to AT&T. Hoping the Kit Kat update fixes this.
  18. #18
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My third replacement device is having more problems. Gps keeps flashing on and off and it loses connection just like my first one. I spent a long time on the phone with tech support the other day but he couldn't find anything wrong with my device. I am starting to lose faith.
  19. #19
    pdqgp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    There's a HUGE 18 page thread on AT&T's forum on this very subject. I'm at the end of my rope. I know for sure it drops when I receive or make a call or receive or send a text. Not sure if it's related to getting an email via push. Will turn my messages back to manual and see. However, it drops way too much to be acceptable for me to keep this phone as is. No way I will tolerate the BS of resetting the device, etc. as it's been this way since I bought it with nothing on it. I've seen resets done on coworkers device and it doesn't work. End that talk please AT&T.
  20. #20
    Uselessbass's Avatar
    Posts
    Global Posts
    247 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guys I have a galaxy s4 active on att and I have the same prob on 4.3 everytime it goes from 4g to 4glte I lose GPS my wife has the note 3 so we both got broken GPS now dam u att
    Sent from my SAMSUNG-SGH-I537 using Tapatalk
  21. #21
    aegould's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I *did* give up...finally. Have gone back to using an iPhone 5S....gave up the nice big screen of the GN 3 for the signal dependency of the iPhone. Have been using the GPS on the iPhone now for three days without a single drop. And yes...I'm still on AT&T's network. Sorry Samsung...better luck next time.
    rusty502 likes this.
  22. #22
    H3aTeRzz's Avatar
    Posts
    Global Posts
    2,590 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank God I use my Garmin for travel and not my Note 3 :-D The thought of being forced to go back to that Teenie-Tiny little phone.....burrrr, scares the heck out of me!!!!!
  23. #23
    rusty502's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by aegould View Post
    To be fair, this seems to only affect AT&T, GPS on the note 3 on other carriers (I'm on sprint) seems to work fine, I use it 15+ hours a week and have never had a single issue, my coworker has the Verizon model, and likewise, no issues, it could be an AT&T specific hardware issue. It's a shame you couldn't find a solution, it really is a wonderful device.
    aegould likes this.
  24. #24
    aegould's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    err...meant to say signal DEPENDABILITY...not dependency
    billmunson likes this.
  25. #25
    aegould's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Guess I'll just have to stick it out and see what Apple's 5.7 inch iPhone 6 is going to look like....if I can still see after all my squinting looking at the 5S :-)
    H3aTeRzz likes this.
  1. Revert to old GPS icon? (it was more informative)
    By gargavf in forum Google Nexus 4
    Last Post: 03-05-2015, 06:18 AM
  2. Lost PIN
    By FBA in forum Samsung Galaxy Note 3
    Last Post: 01-22-2014, 12:41 AM
  3. [FREE] Compass + GPS
    By Raulgame in forum Android App Inventor
    Last Post: 01-21-2014, 01:04 PM
  4. GPS works fine, but cannot navigate?
    By user13398 in forum HTC One M7
    Last Post: 01-20-2014, 09:01 PM
  5. GPS and the Caribbean
    By rjack22 in forum Google Nexus 7 Tablet (2013)
    Last Post: 01-20-2014, 05:48 PM
