Note 3: Screen comes on when battery is lower than 13%
eugchen
77
not sure why it keeps doing what the title says....cant figure out how to STOP this! any ideas?
thanks
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Re: Screen comes on when battery is lower than 13%
thanks
Does it have any notifications or alerts? My phone does it at 14 and 4% to tell me I have a low battery and to plug in. That might be what is happening with yours
eugchen
77
i dont see any notifications or alerts...
it stays on for 20 seconds, then screen turns off (i set the screen to shut down after 20 seconds)....
i do have power saver....but i cant imagine this is saving power!
this isnt the low battery and plug in alert that im talking about. the screen just truns on...and then shuts off after 20 seconds
UJ95x
Retired Ambassador
Aug 26, 2013
9,337
Weird, I haven't seen this happen before. And that's all it's doing? Just turns on at around 15% and turns off again? Doesn't happen at any other times? :eek:
Rukbat
Retired Moderator
Feb 12, 2012
44,529
26
First, you should never (if you can help it) let the battery run down to less than 40%. Constantly running it down to 13% is going to kill the battery before you want to replace the phone.
Then you'll never hit 13%, so you won't have the problem.
kixfan
1,060
16
38
I run my phone on silent most of the time. I noticed that when I get below 20% and the "power saving" features kick in, my sound turns itself on. Sometimes running the battery below 40% can't be helped. I think that is a bit harsh anyway. I could see maybe below 20% but not 40%. If I did that I may never get to leave my house. LOL
Landers2
