Page 1 of 3 123 LastLast
Results 1 to 25 of 66
Like Tree2Likes
    Default Problem with connecting PC with my Samsung Note 3
    I have conected my samsung note 3 to my PC, but the phone doesn't recognize the conection(the PC too), but the phone is charging not knowing it, and th batterys charge is decreasing. Once I restart the phone, I can see the phone has charged to some degree. This repeats each time I try to charge it, I'm thinking that this might be a software problem, since I updated it to the new android version recently. Can I do something about this? I'd like for my pc to be able to see the phone.
    P.S. how can I get rid of the option that music album covers are on my lock screen? Thanks everybody.
  2. #2
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    Default Re: Problem with conection with my Samsung note 3
    Have you tried sliding down the notification bar, clicking the usb symbol, and changing the type of connection?
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
  3. #3
    Default Re: Problem with connecting PC with my Samsung Note 3
    How many amps are you charging with? If too low it technically is charging but you may be using more battery power than what is coming in. Good luck!
    Sent from my Samsung Galaxy Note 3 via Tapatalk.
  4. #4
    hi! I have the same issue and there's no notification on the notification bar to change the type of connection. I've been searching everywhere. I hope there's a fix to this.
  5. #5
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    When you plug the phone into the computer the usb icon should show up. Then you can click on it.
  6. #6
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by ManiaksXLR View Post
    Welcome to the forums.
    Have you downloaded and installed updated Samsung drivers. They can be found at Samsung's website.
  7. #7
    hi again, The usb icon doesn't show up and i have downloaded the usb drivers. My pc can detect the phone but i can't use it as a media device. It stays as charging only.
  8. #8
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Quote Originally Posted by Belle S View Post
    Welcome to the forums. Have you tried what I suggested?
    From a Sprint Moto X using AC Forums app
  9. #9
    hi, yes i downloaded it from here: http://downloadcenter.samsung.com/co..._v1.5.33.0.exe
  10. #10
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Try restarting the PC, different cables and different USB ports.
  11. #11
    I tried using both usb 3.0 and 2.0, different ports, and another laptop.
    USB debugging is also enabled.
    I also tried installing Kies 3 but it says device not supported.
  12. Thread Author  Thread Author    #12
    Sorry for late response. I've tried all of the suggestions, like Belle, the problem persists. Some time ago (before the update) my pc did detect my phone, so I don't think it is an issue with my usb drivers(still tried your suggestions though).
    Concerning the AMPs, if I plug my phone in to the electrical socket, the problem is the same, So might be the wire, but strange that it is still charging unknowingly.
    Also if I reboot my device, while it is connected to PC, and then remove the USB wire from it, it shows that USB connected. I'm thinking that something is wrong with the software.
  13. #13
    mmohn01's Avatar
    Posts
    Global Posts
    390 Global Posts
    I would take it in to at&t then. Sounds like a loose charging port, which is covered under warranty.
  14. Thread Author  Thread Author    #14
    I have turned it off several times, doesn't work. The problem persists.
  15. #15
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Try turning USB debugging off.
    - - - Updated - - -
    It may be a bad USB port. I would have your carrier look at it.
  16. Thread Author  Thread Author    #16
    Wasn't on when the problem appeared. Recently turned it on. Turned off now, still same problem.
  17. #17
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    I think the port in your phone may be bad. Perhaps your carrier can check it.
  18. #18
    I'm not sure if it's the port on my case, though. The phone and PC can communicate with each other through mobogenie but I'm not sure if it's a safe software.
  19. #19
    Do you think I'm missing a driver?
  20. #20
    Posts
    Global Posts
    32,733 Global Posts
    Carrier
    Possibly. Try downloading updated drivers. I think you can get them from Samsung's website.
  21. #21
    before I updated my phone it connected perfectly to my PC and I updatet my phone 4 days ago and now when I connect it to my PC the only thing it does its charging someone help me
  22. #22
    Angry Re: Problem with connecting PC with my Samsung Note 3
    I'm having exactly same problem with my Sprint Note 3.
    - Plugged in phone, it could not detect the drivers.
    - installed drivers from http://downloadcenter.samsung.com/co..._v1.5.33.0.exe
    - This time phone is detected in device manager. But nothing shows up under "My computer" (Windows 7)
    - No notifications in phone
    - This is useless for me since the menu item Storage settings > USB Computer Connection option is unavailable on my phone http://eguides.sprint.com/support/eg..._computer.html
  23. #23
    Same with me Bro
    Sent from my HUAWEI G610-U20 using Tapatalk
  24. #24
    same problem with ma note 2
  25. #25
    I've the same problem I tried everything in this thread and some other searches too, but nothing worked. I don't know where is the problem..
    I tried my Samsung Note3 on another pc and I still had the same problem..
    Please if some one got the solution, share it with us,
    Thnx
  1. Galaxy S3: Samsung Dictionary Much Worse After 4.3 Update
    By GaZZuM in forum T-Mobile Galaxy S3
    Last Post: 03-22-2014, 03:41 PM
  2. LG G2: problems after update
    By d0eb0y in forum Sprint LG G2
    Last Post: 02-12-2014, 06:10 PM
  3. My Moto G is Stuck in Boot Loop
    By AlexBates in forum Moto G (2013)
    Last Post: 02-08-2014, 11:47 PM
  4. Replies: 0
    Last Post: 02-08-2014, 07:02 PM
  5. grainy screen with Zagg
    By anon8523217 in forum Sprint LG G2
    Last Post: 02-08-2014, 05:42 PM
