1. inc55's Avatar
    I recently rooted my note 3 with a kingo root and deleted some apps from the sys/apps folder and my phone has been acting weird ever since. Half the time I open my email it says it had a problem opening. How do I restore my phone to its factory state with all the apps that originally came with the phone? I have removed the kingo root and my phone does not say custom anymore. No more unlock icon when starting either. Knox is at 0x0. Please give me detailed instructions because I am unfamiliar with what roms are and android in general. I recently switched over from a long history of iphones.
    02-27-2014 02:08 AM
  2. inc55's Avatar
    Nobody knows? Factory reset on an iPhone is very easy. Is it really that hard.
    02-27-2014 10:17 AM
  3. ImStevo's Avatar
    I belive that Kingo root installs malware to your phone but the root does work. I belive that's why you ate getting these issues. And I belive the factory reset is in the back up and restore I your settings
    02-27-2014 10:35 AM
  4. inc55's Avatar
    The issues began when I started deleting bloatware. Can anyone tell me how to restore my phone to its factory state with all the apps??
    02-27-2014 11:26 AM
  5. H3aTeRzz's Avatar
    Use Kingo to Unroot....then reboot....then do a factory reset by going Here: SETTINGS>GENERAL>BACKUP & RESET
    02-27-2014 01:11 PM
  6. inc55's Avatar
    I heard resets just clear personal data and that once you delete an app it is gone for good.
    02-27-2014 07:52 PM
  7. yogi2000#AC's Avatar
    Which firmware version are you on? From there we can find a way to restore your system. Perhaps the easiest way would be to keep root and install safestrap recovery, and then you can restore a backup of a stock system.
    But yeah, it is certainly wise to make backups before uninstalling stuff. Or even just freezing stuff rather than uninstalling it. Especially since with this device we don't have a lot of stock firmware files, etc.
    02-28-2014 12:47 AM
  8. inc55's Avatar
    Im on NB4. I rerooted the phone and found the jobmanager.apk file that I deleted which caused certain apps to act weird and now the phone works good again. I still would would like to have a stock recovery. I wanna be able to update to 4.4.2 and do resets if i choose without bricking the device.
    yogi2000#AC likes this.
    02-28-2014 01:51 PM
  9. yogi2000#AC's Avatar
    Gotcha. I actually made a backup of NB4 with nothing removed, using safestrap recovery. The only thing it has is root which is easily removed if desired.
    I could put it in my Dropbox and post a link here later on if you like. When the time comes it can be restored with safestrap. (I won't include my data of course)
    inc55 likes this.
    02-28-2014 02:41 PM
  10. inc55's Avatar
    That would be greatly appreciated. Some instructions would be nice too.
    02-28-2014 03:55 PM
  11. yogi2000#AC's Avatar
    I'm uploading them now, but its gonna take a while lol. I'm putting them in their own thread so others can find them easily, will post the link when it's done.
    I'm putting up the backup that can be restored in Safestrap recovery, and also just the system folder pulled from the device, so in case you remember exactly what you removed, you can just take it from there and put it back into your system.
    I don't see a thread for Safestrap here, but if no one minds you can learn about it and how to use it here: http://forum.xda-developers.com/show....php?t=2572978. You won't have to create ROM slots and all that if you don't want, you'll just need to install it and restore the backup
    02-28-2014 06:04 PM
  12. yogi2000#AC's Avatar
    i finally got the files uploaded and made a thread: http://forums.androidcentral.com/t-s...s-restore.html
    let me know if the links take you to download the files...(never hosted files on Google Drive before)
    hope it helps you!
    H3aTeRzz likes this.
    03-01-2014 11:11 AM
  1. Zync Z5 Phablet Updating and rooting
    By Karthik Kumar1 in forum General Help and How To
    Last Post: 02-27-2014, 04:22 PM
  2. Note taking in large PDFs. Which app do you prefer?
    By starbuckk in forum Samsung Galaxy Note 10.1
    Last Post: 02-27-2014, 11:12 AM
  3. In need of help
    By Kim Carroll1 in forum General Help and How To
    Last Post: 02-27-2014, 10:17 AM
  4. some notifications not working on data
    By mtvictor in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-27-2014, 05:53 AM
