Results 1 to 25 of 25
Like Tree8Likes
  • 1 Post By pounder001
  • 1 Post By Paul627g
  • 10 Post By dpham00
  • 2 Post By dorrien12
  • 1 Post By CHIPINO SALVADOR
  • 1 Post By unclefunbuckets
    pounder001's Avatar
    Posts
    Global Posts
    1,028 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Note 3: Annoying LOUD AT&T start up sound
    Fairly new GN3 user: I have looked around but could not find any way to turn down the annoying very LOUD AT&T start up sound chime every time I turn on my GN3
    I am sure it is something simple to be able to turn down or mute it but I guess I am missing it
    Any help would be appreciated - Thanks
    Chad owens likes this.
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Annoying LOUD AT&T start up sound
    Hello
    Are you talking about the AT & T sound/screen during the bootup of your device? If so then no you can't do anything about that " stock ". Your device would need to be rooted to modify that.
    VDub2174 likes this.
  3. #3
    VDub2174's Avatar
    Posts
    Global Posts
    5,775 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I would assume (if available) that it would be under Settings > Sounds but i honestly forget what the default TW menus have (I have a custom ROM on my Note 3).
  4. #4
    dpham00's Avatar
    Posts
    Global Posts
    24,795 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I use the app "silent boot" from the play store to silence boot up sound. This app doesn't require root. I haven't tried it on an att variant but it worked on my Verizon Samsung Galaxy Note 3.
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    pounder001's Avatar
    Posts
    Global Posts
    1,028 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by dpham00 View Post
    Perfect thanks!
  6. #6
    sqa4life's Avatar
    Posts
    Global Posts
    701 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Silent boot worked. Thanks
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  7. #7
    dorrien12's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You don't have to root it to get rid of the sound. Settings - Device - Sound - Volume - System (turn that down) and then when you reboot you won't here that sound.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    BeverlyX and zylstra like this.
  8. #8
    unclefunbuckets's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Silent Boot didn't work for my Note 3 from AT&T. Even with the first TWO boxes checked. Neither did the Volumn > System.
    pounder001's Avatar
    Posts
    Global Posts
    1,028 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by unclefunbuckets View Post
    My new AT&T N3 worked perfectly with silent boot? I wonder what the difference is
  10. #10
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know but it's a little annoying. I'll just have to deal with it.
  11. #11
    Chuckcell's Avatar
    Posts
    Global Posts
    249 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The boot chime on my Note 3 changed this AM. I haven't changed anything. Could this be part of the KitKat upgrade?
  12. #12
    Chuckcell's Avatar
    Posts
    Global Posts
    249 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    No that was not the boot chime. It was ...
  13. #13
    Chuckcell's Avatar
    Posts
    Global Posts
    249 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Wifi connect(ed) alert. And that is new.
  14. #14
    pdqgp's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Silent Boot worked perfectly on my AT&T Note 3
  15. #15
    chuco35's Avatar
    Posts
    Global Posts
    82 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by dorrien12 View Post
    What else does silencing "system" silence besides the ATT boot music?
  16. #16
    CHIPINO SALVADOR's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Note 3: Annoying LOUD AT&T start up sound
    You need to root your phone buddy, Cause i found that very annoying to. Then download wanam app to turn it off.
    Baugherb likes this.
  17. #17
    cbut's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pounder001 View Post
    Silent Boot was the answer for my HTC One X plus. (Android 4.2.2)
    First of all it didn't work but then I turned off the Fast Boot option (Settings...Power...Fast boot) and it worked fine with only the first option ticked.
  18. #18
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the Silent Boot app tip, that is what I was looking for. I don't mind the death star but come on, pay up to Disney to get the music to go with it.
  19. #19
    Arjan Nihalani's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Post Re: Note 3: Annoying LOUD AT&T start up sound
    dear sir
    i would like to start samsung g 130e model and to know the full details how to use this model for i am a senior citize n of 65years old please explain to me in simple language
    thanks and regards
  20. #20
    pfctor's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks! Great suggestion. App worked perfectly on my Samsung s6 Edge. AT&T sound startup is gone.
  21. #21
    sagal7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That is right. Settings - Device - Sound - Volume - System (turn that down) and then when you reboot you won't here that sound.
    Thanks I have note 3 and now no annoying start-up music
  22. #22
    DonaWise's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This message is for anyone wanting to know how to disable the ATT log on tone: I don't know if the location is the same for all phones; however, for Samsung Notes, go to Systems, Device, Sounds and Notifications, Volume and make sure that the systems volume is set to silence.
  23. #23
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That never worked for many people including me.
  24. #24
    tadpoles's Avatar
    Posts
    Global Posts
    1,154 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You want to hear annoyingly loud? Listen to the Nexus 6 boot up.
    from my old nexus 5
  25. #25
    Steve_Karl's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    G900A here ... System sounds were already set to off but
    Silent Boot works!
    Thanks guys!
  1. AT&T Galaxy S4: is the KitKat update worth it?
    By Rob79 in forum Samsung Galaxy S4
    Last Post: 03-12-2014, 08:33 AM
  2. Samsung Galaxy Note 3 is getting KitKat on AT&T now!!
    By daviddlt in forum AT&T Samsung Galaxy Note 3
    Last Post: 03-09-2014, 11:49 PM
  3. Can't Update to Kitkat on AT&T
    By troshs in forum Samsung Galaxy S4
    Last Post: 03-03-2014, 04:11 PM
  4. AT&T 4.4.2 update removed some things from my S4
    By AlphaVictor87 in forum Samsung Galaxy S4
    Last Post: 02-27-2014, 03:26 PM
  5. AT&T i337 KitKat Updated
    By IAMHADE5 in forum Samsung Galaxy S4
    Last Post: 02-26-2014, 06:22 PM
