Stock NB4 System Dump: https://drive.google.com/file/d/0B2CETO5oJqxFYThxc096ZG9BUVU/edit?usp=sharing
Stock NB4 System Restore(Safestrap): https://drive.google.com/file/d/0B2CETO5oJqxFVENCOGZqZWZPQjg/edit?usp=sharing
The above can be used to restore your system to stock NB4. The system dump is pulled directly from the device, so files can be pulled from there and replaced into your system(in case you deleted apps and don't have them backed up). The Safestrap system restore is a backup made of a stock NB4 system with nothing removed, and can be restored in Safestrap recovery by putting the extracted folder in the same place as your other Safestrap backup go(TWRP/BACKUPS/*device serial number*).
Note: the backup does contain root, which can be easily removed thru the SuperSu app.
