Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By H3aTeRzz
    Rustys Raw Bar Estero's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default note 3 battery dying prematurely
    My note has been off charger for 2 hours and its at 44% battery life. The phone is physically hot near the top. Anyone have any info to fix it?
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    33,070 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: note 3 battery dying prematurely
    Tried a reboot?
  3. #3
    H3aTeRzz's Avatar
    Posts
    Global Posts
    2,590 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'd be curious to see what apps/services are running during the time of issue.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    Golfdriver97 likes this.
  4. #4
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    One of 2 things more than likely; either an app or process gone rogue or a corrupt media file on your SD card if you have one installed. If you have an SD card installed try removing it and restart. See if the problem clears itself. If not, then a reset might be in order.
  1. Note 3: Problem with Firefox after KitKat download
    By Spartiatis in forum Samsung Galaxy Note 3
    Last Post: 03-25-2014, 05:03 AM
  2. Sprint Note 3: default calendar issue
    By jordanretro11 in forum Sprint Samsung Galaxy Note 3
    Last Post: 03-24-2014, 11:24 AM
  3. Purchased my first Samsung Galaxy Note 2
    By Red_Berry_21 in forum Samsung Galaxy Note 2
    Last Post: 03-24-2014, 11:06 AM
  4. Anybody use a tablet or smartpen for note-taking in meetings??
    By drew4392 in forum General News & Discussion
    Last Post: 03-22-2014, 04:45 PM
  5. Huawei G300+ hot and draining battery
    By Treebone in forum Huawei
    Last Post: 03-22-2014, 10:31 AM
