1. richlaustx's Avatar
    I have not been able to successfully use ADM to locate my phone except when on WIFI. I think I have all the settings correct but I am obviously missing something.
    Any ideas? Thanks!
    03-22-2014 11:32 AM
  2. Ealevenish's Avatar
    When what is on WiFi? The phone you're looking for, or the device you're using to locate that phone?
    Maybe (free) AndroidLost works better for you.
    03-23-2014 11:26 AM
  3. richlaustx's Avatar
    Sorry I wasn't clear- when the phone is on WiFi.
    03-23-2014 02:32 PM
  4. Almeuit's Avatar
    Ensure this setting is set.. It is required on devices 4.1 or higher.
    For devices running 4.1 and higher, location access must also be enabled. To turn it on, go to Google Settings > Location > Access location.
    Sent from my T-Mobile Note 3 using AC Forums.
    03-23-2014 03:32 PM
  5. richlaustx's Avatar
    OK, I had to come back to give everyone the solution that to the problem I created for myself. It turns out a couple of months ago I had a rogue app that was consuming data in the background.
    I uninstalled that app but where I went wrong was under Settings>Data Usage> I Restricted Google Services,checked Restrict Background Data. Un-checking that and restarting my phone and Android Device manage has worked perfectly since. It now seems obvious that thus was the problem but maybe it will help someone else sometime. Cheers!
    04-12-2014 06:31 PM
  6. Raptor007's Avatar
    Oddly for me I have done everything mentioned here and I am unable to locate with ADM. Nothing is blocked and every location service is on.
    04-16-2014 06:12 PM
  7. Rukbat's Avatar
    You aren't using Safestrap, are you? Only the stock slot is available for location services (ADM, AndroidLost, etc.) for some reason.
    04-22-2014 02:36 PM
  1. Chromecast: Usable on WiFi Hotspot (2x phones)?
    By Oliver Hyde in forum Google Chromecast
    Last Post: 09-23-2014, 09:34 AM
  2. Sprint LG G2: After installing Google Now on my phone...
    By Carnage Reigns in forum Sprint LG G2
    Last Post: 03-28-2014, 08:33 PM
  3. Update on Tab 3 Kids
    By jedtron in forum Samsung Galaxy Tab 3
    Last Post: 03-25-2014, 07:44 AM
  4. Replies: 1
    Last Post: 03-22-2014, 10:57 AM
  5. yahoo email app - is it on all the time?
    By B45 in forum Verizon Samsung Galaxy S4
    Last Post: 03-22-2014, 08:56 AM
