Results 1 to 3 of 3
    luohan's Avatar
    Posts
    Global Posts
    29 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default HELP....bought a T-Mobile Note 3 and trying to use on AT&T
    I bought a tmobile note 3 from a guy who said it is unlocked. I put my AT&T sim card and the guy changed some stuff in settings and the 4G LTE appeared on the status bar. I am able to make calls and surf the web fine so I thought everything was good. I just realized now that I can't group text nor receive picture MMS text. Is there something I need to change to make it work on the phone? Do I need to contact AT&T? Or am I just stuck without the ability to send group text or receive MMS? I should've just bought an AT&T model. Thanks anyone who can help!!
  2. #2
    H3aTeRzz's Avatar
    Posts
    Global Posts
    2,590 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: HELP....bought a tmobile note 3 and trying to use on AT&T
    Sounds like you just need to adjust your APN settings to represent AT&T model.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
  3. #3
    Sonnydigs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  1. How to Sync S-Notes to a Mac?
    By mfidelman in forum Samsung Galaxy Note 2
    Last Post: 12-02-2014, 12:38 PM
  2. Replies: 3
    Last Post: 03-29-2014, 03:23 PM
  3. Reverse phone lookup on 4.4.2 not working; S4?
    By Helo Darqness in forum Android 4.4 KitKat
    Last Post: 03-25-2014, 09:56 PM
  4. How do you fix scratches on screen?
    By stalemate1 in forum General Help and How To
    Last Post: 03-24-2014, 05:10 PM
  5. Replies: 11
    Last Post: 03-24-2014, 02:41 PM
