While phone is on...pull the battery. Then restart. Worth a try...other than that...A reset is in my opinion the only other option.
Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
biggest thing for me is not being able to save pics to SD card
Thanks for the suggestion. Unfortunately it didn't work. The phone powers back up in a locked screen but when I hit power button to Power off and again to power it on, it unlocks, lol... Wth??? From that point on it never locks again. Anybody else having this issue? Would really hate to hard reset and start all over.
Mines says the same thing it downloaded and then after restarting it said it would install mines get to the blue installing progress bar about 28% then it says update interrupted. But I don't know what is interrupting it?
The update was supposed to give camera access from the lock screen, but I don't see it. Anybody know how to get it?
It did put the camera Icon on my lock screen..
Although it would not respond and open..
I removed it..
Did you swipe the icon rather than just tapping it?
From where? My camera app still saves photos to my SD card.
"Couldn't load plug-in"
Having a problem with both the factory browser and Dolphin browser where they no longer load flash/multimedia built into page. Example would be the article for the new Android pod cast. It won't load it.
I can no longer download files through the Dolphin Browser. It goes right the "file download unsuccessful"
