Page 1 of 4 1234 LastLast
Results 1 to 25 of 80
Like Tree5Likes
    Default Note 3 KitKat fix Asap
    So I have been trying to update my note 3 for the past couple of days to KitKat. Problem is that it downloads then installs like normal until it gets to 27% n then fails. Others have reported the same problem. I'm not rooted and I have contacted Samsung they told me to contact att said it should automatically update over Wifi. I have xfinity so that's not the problem. I tried clearing the Google services cache. Nothing is working.
  2. #2
    Default Re: Note 3 KitKat fix Asap
    I just picked up a note from att and before I left the store the update started so I stayed on their WiFi and waited till it completed with no issues. I know the update said it needed WiFi to download so it sounds like a possible software issue.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  3. #3
    I had to go to Samsung inside Best buy to get mine to update. I just told them it would not update and they said that a lot of people are having the same problem. If you have an AT&T store they can do it also but not AT&T reseller.
    H3aTeRzz likes this.
    So should I go to my local att store. N the only problem with that is I don't have att I just have att phone (N3) with my h2o sim card inside. I didn't think that was an issue because my wife has the s4 also with an h2o sim card and hers updated like 2-3 weeks ago
  5. #5
    Quote Originally Posted by kentuc794 View Post
    Quote Originally Posted by DCBamBam View Post
    Do you have a best buy near you? They should have a Samsung booth that will do it for you.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    No I would have to travel to one which is kinda far since I don't drive . I'm going to try something different this time I have 36 second left until I can check for the update so I'm going to take my sim card out and try it then
  7. #7
    Try updating with Kies
    Posted via my Galaxy Note 3
  8. Thread Author  Thread Author    #8
    I tried that yesterday my N3 connected but then said it was updated to the latest software
    Well it just tried to install again n of course didn't work
  10. Thread Author  Thread Author    #10
    Just got home from work plugged my phone up to Kies and again........nothing
  11. Thread Author  Thread Author    #11
    In a day or 2....yup I'll be rooted....it's ashame but oh well.
  12. #12
    Unless someone releases a stock version of KK for Odin...I doubt you'll ever be able to upgrade. Unless of course you find a way to get it to a Samsung support place and get them to do it. IMO, there is something in your system files that the update doesn't like. Sorry for your troubled bro.
  13. #13
    Or...just root and be happier with many different versions of KK :-)
  14. Thread Author  Thread Author    #14
    Thanks bro I guess I will just root I kinda of didn't want to but oh well....smh
  15. Thread Author  Thread Author    #15
    Wait if I root can I unroot at any point to get an ota if I am able
  16. #16
    That's something I can't answer because I have no clue what was done to KK update that might interfere with un-root. I'm sure there are others here that will hopefully chime in and answer that one for you. Here's the bottom line on that though.... if you root, you'll ALWAYS have access to the update before unrooted users, hence there is no reason to unroot for OTA. I have 2 note 3's,,, one I'm keeping rooted and will just install updated custom roms as they come out (before carrier updates will). The other one I'll keep unrooted...but that's just me.
    I'd go ahead and root, and enjoy life to its fullest, and stop worrying about carrier updates altogether :-D
    PS: I have more fun with the rooted one, than the unrooted one!
  17. #17
    If you don't mind a factory reset, here is a link to the Ota. Keep in mind that it will wipe everything on your device. Don't change the name or anything, just copy the file to EXTERNAL, I repeat, EXTERNAL SD card and go into recovery and apply update. http://fs1.androidfilesharing.com/21...1#.UzgxmtDD_qA
    gbrandonj likes this.
  18. #18
    Quote Originally Posted by putsometrebleinit View Post
    If you don't mind a factory reset, here is a link to the Ota. Keep in mind that it will wipe everything on your device. Don't change the name or anything, just copy the file to EXTERNAL, I repeat, EXTERNAL SD card and go into recovery and apply update. AndroidFileSharing.com
    I don't think his issue is downloading it, its when it starts installing....it stops at 27% which is indicative of a system/size/file change that the update doesn't like. but, its worth a shot I think!
  19. #19
    Quote Originally Posted by H3aTeRzz View Post
    Well, downloading was quite my issue! AT&T Software Update tried to convince me that my Note 3 had the latest software 4.3.
  20. #20
    Had same issue, OTA downloads, reboots and install with progress bar gets to 27% and fails.
    I had rooted with Kingo and unrooted... got the previous OTA fine.
    Went to the AT&T repair center, they checked Knox, still 0x0 (Kingo does not trip knox)
    They flashed (via USB) 4.3 ... then they forced an OTA via their connection to the mother ship, and got the interim release... rebooted, now the mother ship said 4.2.2 now available, again forced the OTA and have 4.2.2
    This forcing of the OTA does not give the usual message, you see a notification that an update is in progress, but nothing else..
    Greg
  21. Thread Author  Thread Author    #21
    So are you running 4.2.2 or now 4.4.2 after they flashed the ota via their connection
  22. Thread Author  Thread Author    #22
    Is this for root like do I need to get a custom recovery first. Cuz u said go into recovery mode
  23. #23
    This is happening quite a bit. Here's the solution: Goto AT&T and get them to flash the update on your device with their system. If the update is indicating that you have the latest firmware, and you don't, then there is a software related issue with your device that can be corrected by letting them flash the KK rom. Now, you can call them and they will push the download to your device, its worth the time if you got it.
    Flyrfan11 likes this.
  24. #24
    How to Boot Into Samsung Galaxy NOTE 3 Recovery Mode
  25. Thread Author  Thread Author    #25
    Ok great bro so should I just go to my local att store and get them to flash it. Cuz if so I don't think they will since I don't have att I have h2o
  1. Best S-Pen Apps (esp. drawing, & note apps)
    By KeenAndroid3 in forum Samsung Galaxy Note 3
    Last Post: 04-01-2014, 06:09 AM
  2. Sprint Note 2: Stock ROMs
    By snowwy66 in forum Sprint Galaxy Note 2
    Last Post: 03-31-2014, 11:43 AM
  3. New Stability Update for Samsung Galaxy Note 3
    By officialclar in forum Samsung Galaxy Note 3
    Last Post: 03-31-2014, 09:14 AM
  4. Rebooting after i turn WiFi on ! NOTE 3 KitKat 4.2.2 update
    By Dimitris Fel in forum Samsung Galaxy Note 3
    Last Post: 03-29-2014, 04:51 PM
  5. Emojis on stock keyboard (Kitkat)
    By Xenuprime in forum Samsung Galaxy Note 3
    Last Post: 03-29-2014, 01:06 PM
