07-08-2014 05:28 PM
30 12
tools
  1. GoBucks2372's Avatar
    I am seeing decreased battery life. I know the screen is a big one... but it seems like the Android system is using more than usual.
    Anyone else? Anyone have any tips on improving it?
    Attached Thumbnails AT&T Note 3 Battery Life - Post Kit Kat Update-screenshot_2014-03-31-14-29-19.jpg
    03-31-2014 01:32 PM
  2. Therealm80's Avatar
    I agree.
    03-31-2014 01:47 PM
  3. H3aTeRzz's Avatar
    Factory reset will resolve that. Unless of course you've already done that after updating to Kit Kat
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    03-31-2014 02:49 PM
  4. charlee08's Avatar
    I'm getting a full days use with over 5 hours of screen on time.
    You'll hear no complaints from me about that.
    Posted via my Galaxy Note 3
    blackmagicwoman likes this.
    03-31-2014 02:50 PM
  5. GoBucks2372's Avatar
    Is there any other solution? Was hoping to avoid that.
    03-31-2014 03:03 PM
  6. H3aTeRzz's Avatar
    You can try going into Recovery mode, and clearing your cache there, it may or may not help. This won't erase any important data.
    To wipe the cache partition, follow these steps:
    Turn off the device.
    Press and hold the following three buttons at the same time:
    Volume Up key
    Home key
    Power key
    When 'GALAXY Note 3' appears on the screen, let go of the Power key but continue to press and hold the Volume Up key and the Home key.
    When the Android System Recovery screen appears, release the Volume Up and Home keys.
    Press the Volume Down key to highlight 'wipe cache partition.'
    Press the Power key to select and wipe the cache.
    With 'reboot system now' highlighted, press the Power key to restart the device.
    03-31-2014 03:37 PM
  7. Jake Cukich's Avatar
    I was having the same problem. I let my phone die completely. Then charged it while it was off still. Till 100 percent. Been fine ever since
    03-31-2014 04:47 PM
  8. pmr6644's Avatar
    Reports are there's going to be a android 4.4.3 update roll out relatively soon to fix this problem, apparently it's something to do with a camera battery drain issue present in the current build of 4.4.2, why this wasn't caught before rolling it out to everyone I'll never know. I too am experiencing worse battery life and high android os usage.
    03-31-2014 05:53 PM
  9. Jnorton2724's Avatar
    Decreased battery life. Getting about an hour less screen time after running kit Kat for acouple days. Switching to a larger battery anyway soon so not to worried about this.
    03-31-2014 05:58 PM
  10. jneusch's Avatar
    Battery life is really good since the update. To be fair, it was a clean install. Factory reset of 4.3, then upgrade to 4.4.2, then reinstall apps, etc.
    14+ hours on battery with 5+ hours of phone time, almost 2 hours screen time, corporate push email and 51% battery. This is about 10% better than what I was seeing before KK. I hope it continues.
    03-31-2014 07:50 PM
  11. pappyfire's Avatar
    Mine's about the same as it was.
    03-31-2014 07:55 PM
  12. conanheath's Avatar
    Android OS is using twice the battery my screen is. Never have anything use more battery than screen.
    ATT N3
    03-31-2014 11:06 PM
  13. H3aTeRzz's Avatar
    And the survey says......FACTORY RESET. :-D
    rgriffin25 and jneusch like this.
    04-01-2014 07:46 AM
  14. Delta Mike's Avatar
    Tried the partition cleaning and the system draw is now below the screen for power consumption. Seems to have worked.
    H3aTeRzz likes this.
    04-01-2014 02:09 PM
  15. rgriffin25's Avatar
    I agree with the factory reset. Why play around with all this other stuff. After my factory reset my battery is way better than with 4.3. I'm glad I spent the time to do the reset.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    skyrocketeer, H3aTeRzz and jneusch like this.
    04-01-2014 05:41 PM
  16. o4liberty's Avatar
    I am going on three days as a new Note 3 owner and so far I am getting 12 hours on the battery and I am a heavy user.
    04-01-2014 06:08 PM
  17. Expydude's Avatar
    Not too shabby
    04-01-2014 06:58 PM
  18. H3aTeRzz's Avatar
    THIS!!
    skyrocketeer likes this.
    04-02-2014 06:32 AM
  19. ehosey2's Avatar
    I was losing around 2 hours of battery life compared to 4.3 so I ended up doing the complete wipe and re-install. I will evaluate over the next few days.
    Sent from my Samsung Galaxy Note 3.
    04-02-2014 07:01 AM
  20. Rnkriis's Avatar
    Same here for me... Battery life was less than normal and noticed at some points the phone was getting hot and then the next thing i know, the battery went from 30% to dead and the phone was off. Did a factory reset and everything has been great, i only wished Android had a back up set up like Apple due to having an app for my work that has to be reset every time this happens. I love my Note 3 but this is one one thing i really do miss the most.
    jneusch likes this.
    04-02-2014 09:24 AM
  21. Gary02468's Avatar
    Kies 3 lets you back everything up, including your app data.
    04-02-2014 01:31 PM
  22. ehosey2's Avatar
    Good concept but not so perfect execution. I used it yesterday to perform a "complete" backup before I did a complete wipe. I had some battery drain issues after installation of 4.4.2 so I tried Kies 3. The restore operation had taken 5 hours and completed 67 percent and then completely stopped. I am not sure what happened. So I ended up setting up the phone again from scratch and then used Kies 3 in stages, recovering messaging and phone data as well as some applications. I ended up just downloading most of them and used a backup I saved in Nova Launcher Prime to get my pages set back up. So in the end everything is back on my Note 3 and it is already noticeable that the battery drain problem I was experiencing is gone. It took longer than I liked but in the end I am happier with the battery life and it is at least comparable to when 4.3 was installed. I will continue to test and document with the screen shots I have recorded.
    04-02-2014 01:58 PM
  23. ehosey2's Avatar
    Please keep in mind this is a non-scientific test but I will monitor for a few days and will document accordingly.
    Attached Thumbnails AT&T Note 3 Battery Life - Post Kit Kat Update-1396465343623.jpg   AT&T Note 3 Battery Life - Post Kit Kat Update-1396465375478.jpg
    s_banks likes this.
    04-02-2014 02:03 PM
  24. rgriffin25's Avatar
    I use helium to back up my apps. It's worked quite well. Sure helped shorten the time it takes to get everything back to normal.
    04-04-2014 08:48 AM
  25. pmr6644's Avatar
    So I noticed by use of the app CPU spy that once I turn on my mobile data or Wi-Fi my phone will no longer go into deep sleep even when I turn them back off again. I turned off everything that could possibly be trying to sync as well as every app on my phone that can be turned off and nothing has helped. My phone is in a constant state of being awake no matter how long the screen is off. Its crushing my battery.
    04-04-2014 12:51 PM
30 12
  1. MMS Compression on AT&T HTC One (M8)
    By astarling10 in forum HTC One M8
    Last Post: 05-01-2014, 07:28 PM
  2. Replies: 8
    Last Post: 04-05-2014, 10:42 AM
  3. Are all Verizon Note 3's 32GB ?
    By felloffthetruck in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-01-2014, 05:58 PM
  4. Android OS battery drian
    By Sethoth in forum Google Nexus 5
    Last Post: 04-01-2014, 09:10 AM
  5. Problem with Claro Note 3 in Puerto Rico?
    By Ian B in forum Samsung Galaxy Note 3
    Last Post: 03-31-2014, 12:49 PM
