Results 1 to 17 of 17
    Sonnydigs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default The best car mount for the Note 3..........Is
    First I'm sorry if this has been asked but can't find anything in searches..
    I'm looking for a quality built car mount for N-3..
    I've bought several different mounts over the years for various phones only to receive them and find that they are junk..
    Seems for the most part the are cheaply made of plastic and break or wear out in no time..
    The biggest problem is vibration, can't even tell what is on the screen..
    I'm open to any type, other than floor or Cd mount..
    Any help with the name of, or link to a well built sturdy car mount would be much appreciated..
    Thanks..
  2. #2
    jlynskey79's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: The best car mount for the Note 3..........Is
    I use a ram mount with scissor holder connected to my rear view mirror. It is the perfect setup. Keeps phone for navigation in view.
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    Sonnydigs likes this.
  3. #3
    Baugherb's Avatar
    Posts
    Global Posts
    45 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check out this item I found on eBay: http://rover.ebay.com/rover/1/711-53...3D330845040664
    I've used this for almost a year. With a otterbox case and a smaller sized case without any problems. Cheap in price but works great..
    Posted from my Note 3.
  4. #4
    Baugherb's Avatar
    Posts
    Global Posts
    45 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    And you could always buy a plastic mounting disk to out it just about anywhere..
  5. #5
    rgriffin25's Avatar
    Posts
    Global Posts
    140 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Check out iOttie on Amazon. http://www.amazon.com/gp/aw/d/B007FH...cUvbUpU3554886
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    Sonnydigs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks...
    So it will work with the note-3?
    I have ordered it..
    * Update:
    Just cancelled the order..
    Reviews say it won't fit in the holder if it is in a protective case..
    Mine is in an I-Blason case..
    Too bad, it sounded great..
  7. #7
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    IBolt is what I use. Works with a case. I have been using for over a year. I bought it for my Note 2.
  8. #8
    rgriffin25's Avatar
    Posts
    Global Posts
    140 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Sonnydigs View Post
    Thanks...
    I have ordered it..
    * Update:
    Yes it will work with case. I've not had any problems.
  9. #9
    dpham00's Avatar
    Posts
    Global Posts
    24,807 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I have a Trident Kraken ams case and bought an arkon car mount
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
  10. #10
    Xopher's Avatar
    Posts
    Global Posts
    4,732 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    All Stock
    My favorite mount is from SlipGrip. They are sold through eBay, so just search for them on there. The mounts are custom formed, so you need to select phone model and account for the case (if you use one). I use a Seidio case on mine that has the flip-out stand. They have a mount that accounts for the stand, and has an opening for the camera, so it can be used as a dash cam.
    I have one for my car, and a RAM Mount version on my motorcycle.
  11. #11
    Raptor007's Avatar
    Posts
    Global Posts
    6,963 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have used ProClip Car Phone Holders and Dashboard Phone Mounts-ProClip USA car mounts which are really nice, but now I prefer a more mobile option like Samsung's Samsung Galaxy Universal Suction Car Mount Kit for Samsung Galaxy Phones so I can take it with me in any car, rentals, wifes car etc.
  12. #12
    w7sg's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  13. #13
    JRDroid's Avatar
    Posts
    Global Posts
    1,553 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm currently using the vent mount version of this Clingo mount. It works fantastic. You do have to clean the sticky pad ever 6 weeks or so, but it will hold the phone in pretty much any case that has a flat back. I haven't tried it with a folio style cover, but I could see it not working well in that situation. Other than that, excellent mount that will work with any phone (though it does work better with flat backs like the Note than it does with curved backs like a HTC One or Moto X).
  14. Thread Author  Thread Author    #14
    Sonnydigs's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I ordered it but it doesn't fit with the Iblason case on it..
    No worries just have to remove the case when I use it..
    Thanks to all for the replies..
  15. #15
    Rukbat's Avatar
    Posts
    Global Posts
    22,840 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Modified Stock 4.4.2
    I don't like suction cup mounts because the suction cup dries up after a few years, and you can throw the mount away. My doesn't like them because they leave rings if you mount them on the windshield, and if you glue on a little disk to the dashboard, it's there, mount or not.
    I use the Mountek mount (you get it through Amazon). It mounts in the CD slot. And it holds a Note 3 with an iBlason case. So far it's fallen out once - and I thought I broke a shock I hit that pothole so hard.
  16. #16
    scottwood2's Avatar
    Posts
    Global Posts
    50 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't currently have a RAM mount but I have used many of them over the years. I have one setup on my boat. It has to be solid on there with rough seas. They work great. You pay a little more for it but if you want solid, RAM mounts are very good.
  17. #17
    zapfrog's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All the ones I have used always lose suction or something breaks until... I found this one http://mobile.walmart.com/ip/Scosche...vices/16480628
    I've had it for almost three years now and no problem. Works with my note 3 which is in a Trident case.
  1. How is It?
    By LlamaGS in forum HP Chromebooks
    Last Post: 01-26-2016, 02:21 PM
  2. Best SMS App for the Moto X
    By DonB in forum Moto X (2013)
    Last Post: 04-05-2014, 01:22 PM
  3. Replies: 19
    Last Post: 04-04-2014, 10:49 AM
  4. best case?
    By garethrdwilliams in forum HTC One M7
    Last Post: 04-03-2014, 05:32 AM
