1. Bosk_77's Avatar
    For those that have been using FoxFi (and it works) and just hitting the home button when you get the "To enable mobile hotspot on this device, go to att.com/mywireless or dial 611". If you have updated to Kit Kat, does that still work?
    04-07-2014 12:26 PM
  2. srkmagnus's Avatar
    According to this thread: Foxfi on NOTE 3, users are reporting that home button still works. Hopefully that's still the case if you plan on getting the device or if an update has caused problems.
    04-07-2014 03:29 PM
  3. Bosk_77's Avatar
    I know it works with 4.3. From the looks at other threads there is a Kit Kat update out there somewhere. If there is, I don't want to take it if it causes FoxFi to not work.
    04-07-2014 08:29 PM
  4. srkmagnus's Avatar
    Awe, OK. I suggest keeping an eye on the Play Store comments to see if this is still an issue.
    04-07-2014 10:13 PM
  5. Nchaka's Avatar
    I couldn't get Foxfi hotspot to work after updating to Kit Kat. But I tried using the hotspot feature on my Note 3, and it showed that it was using the same foxfi hotspot name that I had set up.
    I was waiting to get the message that I had to set up the portable hotspot with at&t, but I didn't get it. I will have to watch my bill to see if they charge me.
    04-26-2014 04:35 AM
  6. xaqattax's Avatar
    It looks like it turns on but doesn't broadcast. Solutions for other carriers are popping up but I haven't seen one for Note 3 on AT&T with or without root.
    05-22-2014 03:29 PM
  7. Brownhornet34's Avatar
    I didn't realize this would work but fox fi works perfectly after I changed to shared data plan.
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    05-25-2014 06:19 AM
  8. Xingularity's Avatar
    Because shared data plan includes tethering thus not needing to use foxfi. Us still hanging on to their unlimited plans are still S.O.L.
    Brownhornet34 likes this.
    05-25-2014 05:14 PM
  9. Brownhornet34's Avatar
    Awww...I see says the blind man..I shall be rid of the Fox then. Thanks for the Info.
    Xingularity likes this.
    05-25-2014 05:16 PM
  10. systemsbiologist's Avatar
    FoxFi stopped working for me after upgrading to 4.4.3. Pressing the home button no longer works.
    Any one else having this issue? Any ideas?
    Thank you,
    Tom
    06-22-2014 11:46 PM
  11. Xingularity's Avatar
    Starting with Kit Kat (4.4) tethering provisioning is done at the OS level not at the APP level.
    06-27-2014 05:32 AM
  12. Jerry Parish's Avatar
    Is there a way to go backwards to get the old software so it will work again?
    07-11-2014 10:53 AM
  13. Nchaka's Avatar
    I use the hotspot feature on my phone. With 4.4.3, it seems to have tied Foxfi into the hotspot on the phone. I used for 2 days when visiting my Dad, and was never charged for the feature by at&t. And they never warned me that I needed to sign up for it.
    07-11-2014 11:06 AM
  1. Replies: 16
    Last Post: 11-24-2016, 12:07 PM
  2. Black and White Lines/Stripes Camera
    By Robin Elizabeth in forum Samsung Galaxy S4 Google Edition
    Last Post: 05-15-2014, 05:41 AM
  3. Touchwiz has stopped working - Galaxy Note 3
    By GoBucks2372 in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-11-2014, 12:03 PM
  4. Replies: 7
    Last Post: 04-09-2014, 05:08 PM
  5. Running Kit Kat on HTC One Max from Verizon
    By daero93 in forum HTC One Max
    Last Post: 04-08-2014, 11:29 PM
