1. daviddlt's Avatar
    So..my note 3 has the heartbleed bug vulnerability..what now??
    04-09-2014 04:43 PM
  2. daviddlt's Avatar
    Running kit kat 4.4
    04-09-2014 04:43 PM
  3. superlawyer15's Avatar
    This is interesting...
    I read somewhere earlier today (will try to dig up the source) that only android 4.1.1 was vulnerable
    04-09-2014 05:42 PM
  4. DurhamHusker's Avatar
    I got the same results using my Sprint Galaxy S3 running Android 4.3
    Interesting, indeed ....
    04-09-2014 09:08 PM
  5. daviddlt's Avatar
    Not buy anything till we receive an update? I asked Samsung USA on twitter...well see what they say
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    04-10-2014 01:38 AM
  6. Sonnydigs's Avatar
    Not sure what this all means but here is what I got on AT&T, N-3....
    04-10-2014 10:14 AM
  7. mavrrick's Avatar
    Yea. I have to ask.
    1. Is this a ATT NOTE3.
    2. Is it rooted or have anything done to change the firmware from stock.
    04-10-2014 11:32 AM
  8. Sonnydigs's Avatar
    Yea. I have to ask.
    Yes, Note-3..
    No rooting, totally stock..
    04-11-2014 07:59 AM
  9. mavrrick's Avatar
    Yes, Note-3..
    Actually I was referring to the OP. I ran the scanner from the Lookout folks and it says pretty much the same thing. Yes my Note 3 has a effected version, but the feature the exploit uses is not enabled.
    04-11-2014 10:20 AM
  10. Almeuit's Avatar
    Checked mine. It isn't enabled so I am okay.
    T-Mobile Note 3 running 4.3 still.
    Sent from my T-Mobile Note 3 using AC Forums.
    04-11-2014 11:15 AM
  11. dpham00's Avatar
    Same on my Verizon
    dpham00, Android Central Moderator
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    04-11-2014 11:20 AM
  12. H3aTeRzz's Avatar
    04-11-2014 05:41 PM
  13. mavrrick's Avatar
    Very interesting video. Very miss leading though. It is a big problem but that is sensationalism at its best. The guy doesn't have a clue, the women is a little bit better, and the text on the screen seemed most accurate. Which do you think got most people's attention.
    The guy makes it seem no one is secure and everything is wide open.
    Oh well.
    04-11-2014 07:48 PM
  14. daviddlt's Avatar
    Samsung has yet to answer my question...sigh
    04-11-2014 08:19 PM
  15. mavrrick's Avatar
    The phone isn't vulnerable. If you look at the several subsequent post the feature in question is disabled by default. You only need to worry if you are using a custom ROM and the person that made it, turned it on.
    This is also a server side exploit, not client side.
    04-11-2014 09:03 PM
  16. Nana Helen's Avatar
    Probably a dumb question, can PC's be affected by this virus? I know it can't get into Apple devices, but some of my apps i have on my phone, tablet & PC. Like AC Forums,Evernote etc
    Sent from my GT-I9100 using AC Forums mobile app
    04-12-2014 07:21 AM
  17. Gary02468's Avatar
    That's off-topic. This forum is about AT&T Note 3s, not about Heartbleed on PCs. (Also, Heartbleed isn't a virus.)
    04-12-2014 08:28 AM
  18. Nana Helen's Avatar
    Sorry didnt know what SSL meant & couldnt find anything else.
    04-12-2014 08:55 AM
  19. mavrrick's Avatar
    SSL or Secure Sockets Layer is one of the main method for any computer to create a secure connection. That includes Apple. The key here is what version of SSL are they using and is the heart beat functionality turned on. The Note seems to be a great example of a device having the effected openSSL code but not using the feature so it is still safe.
    Nana Helen, Expydude and UJ95x like this.
    04-12-2014 09:43 AM
  20. mavrrick's Avatar
    This isn't a virus but a software bug. Any computer device mobile, pc, apple, Linux, tablet could be effected if it uses the effected version of OpenSSL and had that heart beat feature turned on.
    04-12-2014 09:46 AM
  21. Nana Helen's Avatar
    Thanks Mavrrick
    I tried to do a thumbs up thanks on both yr posts, but they were denied.
    I appreciate the info now i can research with a bit more understanding.
    04-12-2014 11:11 AM
  1. Samsung Note 3 Weather can not locate my location
    By nnguyen0128 in forum T-Mobile Samsung Galaxy Note 3
    Last Post: 04-15-2015, 04:59 PM
  2. What issue do i have with my n7000?
    By thewildwarriors in forum Samsung Galaxy Note
    Last Post: 04-15-2014, 09:52 AM
  3. Replies: 6
    Last Post: 04-10-2014, 01:10 PM
  4. Galaxy S4: Battery Issue
    By revjasonblanton in forum Samsung Galaxy S4
    Last Post: 04-09-2014, 05:19 PM
  5. Strange root issue for Verizon Galaxy Note 3
    By smccloud in forum Verizon Samsung Galaxy Note 3
    Last Post: 04-09-2014, 01:44 PM
