What version are you running? 4.3? 4.4 KITKAT? If you're using 4.3, you'll need to use SafeStrap to put roms on your device. The Bootloader is not unlocked. Search youtube for using safestrap on your device. Now, if you're on 4.4 KITKAT, there is nothing available for it right now, "I think". Good Luck.
