Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By Closingracer
    Jennifer Perkins's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Begging for a Guru's help
    I just received my chromecast today. The first instruction I got was to download a chromecast app from the playstore. I clicked on the link and it said "this is not compatible with any of your devices." Stress begins... I then I set up the chromecast on my television through my laptop. Awesome, it works with my laptop after downloading Google chrome and downloading the chromecast extension.
    Now I have no idea what to do with my phone - Samsung Galaxy note 3, Android version 4.2.2
    If anyone has the patience to help me I would appreciate it sooooo much.
    Jennifer
  2. #2
    Closingracer's Avatar
    Banned
    Posts
    Global Posts
    4,806 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Begging for a Guru's help
    If you use an app that already supports it is very easy to work. Lets just take Netflix for an example there should be a button on the top right of the screen next to the Search button. It should then ask if you want to watch on this Device of the Chromecast
  3. #3
    Banned
    Posts
    Global Posts
    4,806 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Sent from my SM-N900T
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm checking now, but it didn't show up on my YouTube app. Let me finagle a minute.
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm such a DORK.... So what happened in this thread stays in this thread.... like Vegas. I thought I had to do some setup like I did on my laptop....
    Thank you for taking time to help me. You guys sooooo ROCK!!!
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Closingracer
    You're the BEST, said guys bit it's you that totally ROCKS
  1. Required format for Alternative Password for Fingerprint Scanner
    By kilofoxtrot in forum Samsung Galaxy S5
    Last Post: 09-07-2016, 02:39 PM
  2. Any update on getting hancom word for the note 2014
    By Nychotxxx in forum Samsung Galaxy Note 10.1
    Last Post: 04-30-2014, 06:14 PM
  3. little help with an app
    By John Ball1 in forum Samsung Galaxy Note Pro 12.2
    Last Post: 04-30-2014, 06:08 PM
