1. Eric Schall's Avatar
    Total noob here, but I've been reading. I had been trying to root my phone for a few days, nothing worked on my smn900a. Today I rooted it with Klingo. It worked fine and was totally easy. It booted up fine, no probs had the little unlocked logo with the word "custom" under it each time. Then I tried to do the KitKat upgrade with these intructions ( ) It didn't make it through ok. Now it won't boot past the initial Samsung logo.
    I have tried downloading the original .tar file from samsung mobile and using odin (both 307 and 309) I get a fail message each time. I have tried opening Odin as Admin because one of the forums said that might work..nope. I have exhausted all attempts before posting here. I start a new job tomorrow and I need my phone. A little help?
    04-30-2014 06:58 PM
  2. Eric Schall's Avatar
    After tons of searching, this post enabled me to flash with odin. (All previous attempts with odin had failed) then i did a full factory reset.
    04-30-2014 09:38 PM
  3. Golfdriver97's Avatar
    Are you fully up and running?
    Sent from my HTC One_M8 using AC Forums mobile app
    04-30-2014 11:24 PM
  4. H3aTeRzz's Avatar
    I had to use that method a while back....a life saver it was!!!
    05-01-2014 03:03 PM
  5. Eric Schall's Avatar
    Yup, good to go now
    H3aTeRzz likes this.
    05-01-2014 06:45 PM
  6. Golfdriver97's Avatar
    Yup, good to go now
    Awesome. Glad to hear it.
    05-01-2014 09:31 PM
  1. S3 won't turn on after factory reset
    By ruca32 in forum AT&T Galaxy S III
    Last Post: 01-09-2017, 03:11 PM
  2. Custom logo on boot screen?
    By cplax92 in forum Samsung Galaxy S5
    Last Post: 08-14-2016, 11:11 PM
  3. Can't get out of boot-loop
    By Julia Jooblea in forum HTC One M7
    Last Post: 05-01-2014, 07:26 PM
  4. Replies: 0
    Last Post: 04-30-2014, 06:04 PM
  5. Begging for a Guru's help
    By Jennifer Perkins in forum AT&T Samsung Galaxy Note 3
    Last Post: 04-30-2014, 05:51 PM
