1. mrxmry's Avatar
    Hi Guys,
    I am fairly new to the Android system. I have unfortunately accepted the 4.4.2 update so I believe rooting is out of question for now. However, the phone seems to be loosing battery power too fast now after the update and there is a constant "message expired or not available" pop-up message in the lower section of the screen.
    The phone works well in the safe mode. So I assume there was something wrong with the update.
    I feel like it would be good to update again to a clean version of rom, debloated of the ATT stuff, I just want the phone to work well and I do use the S-apps from samsung so I want those. How do I do it?
    Thanks!
    - P
    05-06-2014 10:31 PM
  2. Zacharyw70's Avatar
    Have you tried completely hard resetting the device after installing the update and then trying performance out? That's what I did after I installed the update when I bought my device and I haven't ran into any issues so far.
    To do it I believe you turn the phone off then hold the Menu Button, Volume Up button, and the power buttons until it turns off and goes in the recovery start up.
    Also I'm not that tech savvy when it comes to "Rooting" and "Flashing" but don't you need to be rooted before you can do any of that stuff?
    05-06-2014 10:56 PM
  1. SM-G900H (Exynos) users - Do any 64GB cards work for you?
    By 1AvgUser in forum Samsung Galaxy S5
    Last Post: 06-09-2014, 04:13 PM
  2. Replies: 2
    Last Post: 05-10-2014, 09:23 AM
  3. Anyone hear/read anything about an upcoming firmware update?
    By U4icLab in forum Samsung Gear 2 & Gear 2 Neo
    Last Post: 05-06-2014, 09:56 PM
