1. wendy5001's Avatar
    I broke up with YouMail and now I'm not getting any voicemails, I'm just sticking with AT&T for now. How do I get it back?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    05-12-2014 01:47 PM
  2. mavrrick's Avatar
    There is a setting in the phone that dictates where the voice mail goes. I don't know how to get it back though without doing a factory reset. Probably have to input some service codes to do it.. You should be able to call ATT and have them help you reset it.
    05-12-2014 01:56 PM
  3. kentuc794's Avatar
    If you have you mail installed still there is a button to deactivate it. If you already uninstalled it the go to your phone click on settings buttons go to call settings. Then click on voicemail settings. You will need to find someone that has the same carrier to find the service number that you need to input.
    05-12-2014 05:04 PM
  4. Irek Roszkowski's Avatar
    Press those codes then CALL button after each:
    ##61# then "CALL"
    ##62# then "CALL"
    ##67# then "CALL"
    This works for AT&T only and resets settings to third party voicemail services.
    05-06-2015 09:42 AM
  5. kixfan's Avatar
    Well now that a YouMail rep is here, how about telling me why it keeps logging itself out and not notifying me of voicemails until I open the app and login again? I'm pretty close to going back to AT&T voicemail too.
    07-02-2015 11:52 AM
  6. kixfan's Avatar
    Yes I have. Quite a few times.
    07-06-2015 08:32 AM
  7. kixfan's Avatar
    Okay. Downloaded it and giving it a try. Thanks for your help.
    07-06-2015 07:25 PM
  8. kixfan's Avatar
    The link won't open for me. I tried on my phone and computer.
    07-07-2015 10:13 AM
  9. kixfan's Avatar
    Firefox on the PC and I tried Chrome and Dolphin on my phone.
    07-07-2015 11:35 AM
  1. My Nexus 5 Is Dead!
    By AndroidDario in forum Google Nexus 5
    Last Post: 05-13-2014, 12:06 PM
  2. My N8000 has only one status bar
    By Renuka S A Devi in forum Samsung Galaxy Note 10.1
    Last Post: 05-12-2014, 12:44 PM
  3. Sound disappeared from my phone's video once uploaded to facebook
    By sweetbw7 in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 05-12-2014, 12:26 PM
  4. galaxy gear draining my note 3 battery
    By amdroidboi in forum Samsung Galaxy Gear
    Last Post: 05-12-2014, 11:28 AM
  5. Would it help if I reset my phone???
    By kilofoxtrot in forum Samsung Galaxy S5
    Last Post: 05-12-2014, 10:38 AM
