07-02-2014 06:55 PM
30 12
tools
  1. fiat3192's Avatar
    What's a good case that's not bulky and protects ur phone
    05-14-2014 01:11 PM
  2. Beyond Fire's Avatar
    You should check out some cases over at Spigen. They make some quality cases that are relatively inexpensive. The Neo Hybrid is probably their most popular case.
    Galaxy Note 3 | Cases and Screen Protectors for Galaxy Note 3 by SPIGEN SGP | Spigen
    Spencerdl likes this.
    05-14-2014 01:17 PM
  3. fiat3192's Avatar
    I had the neo hybrid and returned it
    I'm using the Uag right now
    05-14-2014 03:05 PM
  4. fiat3192's Avatar
    What spigen case do u have
    05-14-2014 03:10 PM
  5. fiat3192's Avatar
    Does the white get dirty fast
    Don't know if I should get in black or white
    But I have the white note
    05-14-2014 06:01 PM
  6. fiat3192's Avatar
    How is the case is it worth buying?
    05-14-2014 09:36 PM
  7. fiat3192's Avatar
    Is it worth buying
    Sent from my SAMSUNG-SM-N900A using AC Forums mobile app
    05-14-2014 11:03 PM
  8. fiat3192's Avatar
    THIS IS AN ERROR THREAD
    05-14-2014 11:08 PM
  9. ImStevo's Avatar
    Neo hybrid!!!
    05-15-2014 12:15 AM
  10. fiat3192's Avatar
    How's it on drops
    05-15-2014 01:00 AM
  11. jcampbell1070's Avatar
    I got the black one. But the case is great. The s view never worked right so I just took the chip out.
    05-16-2014 12:15 AM
  12. fiat3192's Avatar
    I'll just keep my uag case
    05-17-2014 12:23 PM
  13. Morpheus's Avatar
    Diztronic
    Posted via Android Central App via Note 3
    05-17-2014 08:47 PM
  14. CHIPINO SALVADOR's Avatar
    I like the Slim Armor View case by spigen. The white one, the size doesn't bother me at all. Well its a case that will protect your phone better that most cases out their. The case doesn't get dirty as much as you would think it would. I took a gamble with it and im happy i bought this case. By the way if your rooted its 10 times better.
    05-19-2014 02:05 PM
  15. nettech207's Avatar
    surprisingly no one mentioned otter cases I have one on my Note 3 and they provide great protection
    Starchild72 likes this.
    05-19-2014 10:06 PM
  16. Megan Arlitz's Avatar
    The new otter boxes aren't to bad actually. I got one for mine and it's really isn't to bulky at all.
    05-21-2014 05:39 PM
  17. Brownhornet34's Avatar
    The slim armor protection is a joke , it shifts the weight of the note 3 when failing to drop face first .I cracked my screen from a 2" drop on a hard surface, the case had made its way to thr nearest trash barrel. Hello Otter Box commuter case . I replaced the screen myself but patience is a must
    Sent from my SAMSUNG-SM-N900A using Tapatalk
    05-25-2014 06:25 AM
  18. convert's Avatar
    I went with the Otterbox Defender. It has the built in screen protector. It still can fit in a front jeans pocket. It's expensive though, but it's become my preferred case from my iPhone days. You can order it in a custom color arrangement, or just go to Best Buy and get one. I ended up getting the black case since it was the only one they had, but I'm fine with that. The only thing is that if you carry an extra battery and exchange the battery frequently, it would be a pain since you have to take the case apart to do that. But I don't need to remove the back cover often so it works for me.
    Jamie Wooten and Starchild72 like this.
    05-25-2014 07:56 AM
  19. Jamie Wooten's Avatar
    Hmm do they all come with screen protectors on them? The one i'm looking at doesn't appear to have one. I'm thinking about a wallet case, has anyone used anything like that?
    06-03-2014 04:40 PM
  20. convert's Avatar
    The Defender series is the one that has the built in screen protector. The Commuter one offers I believe a film one that you put on yourself. Other cases by other manufacturers I can't speak to. I know people who use wallet type cases and it suits their needs but I can't speak to that as it's not my cup of tea.
    Jamie Wooten likes this.
    06-04-2014 04:51 AM
  21. Jamie Wooten's Avatar
    Thanks for the info. Guess I'll wait to see how much bulk the otterbox adds.
    06-04-2014 06:58 AM
  22. Spencerdl's Avatar
    This is the one I use and the OEM S-View case in black. I don't want to add bulk to an already massive device
    06-04-2014 08:08 AM
  23. Starchild72's Avatar
    I got the Otter Box Defender series and i'm happy with it. Another nice thing about it besides the built in screen protector, Is that the clip attachment also acts as a dock or phone stand
    Megan Arlitz likes this.
    06-04-2014 04:46 PM
  24. ecchigo's Avatar
    Anyone know a good alternative to Samsung's Galaxy Note 3 S-View Flip Cover folio case that also has all it's functions especially the Auto wake/sleep fuction? Its just seems too expensive for me.
    06-18-2014 08:15 PM
  25. Jamie Wooten's Avatar
    You should check eBay. I was looking last night and found some for $29
    ecchigo likes this.
    06-22-2014 06:55 AM
30 12
  1. contact list for texts vs email list
    By Philip Levine in forum Moto X (2013)
    Last Post: 05-14-2014, 01:12 PM
  2. Interactive case
    By ED_DARF in forum Cases, Skins and Screen Protectors
    Last Post: 05-14-2014, 11:24 AM
