Results 1 to 6 of 6
    Starchild72's Avatar
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default TouchWiz problem
    Every time I close an app this happens. I hit always each time to. Anyone else have this issue. How do I fix it?
    Sent from my SAMSUNG-SM-N900A using Tapatalk
  2. #2
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: TouchWiz problem
    First two things I would try would be to boot into recovery and clear the cache. And then go into settings - default applications - and choose the one you want as default.
  3. #3
    jneusch's Avatar
    Posts
    Global Posts
    1,196 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jpr View Post
    Good suggestion. Better to try this before doing a factory reset.
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I tried this and it didn't work
  5. #5
    jpr
    jpr is offline
    jpr's Avatar
    Posts
    Global Posts
    1,702 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    OK, my next suggestions are:
    Turn back on any pre-installed apps you disabled - all of them - and reboot. See if it fixes it.
    Did you ever install any third party launchers? If so, reinstall it/them and set it to default. Reboot and then set touch wiz to default. Then uninstall the 3rd party launchers.
    Did you install, update, or uninstall any apps before this started? Try uninstalling or reinstalling those.
    And this I'm not sure if it was a fluke for this other person but I remember reading here before that uninstalling Google search updates solved their problem. So you could try that.
    Posts
    Global Posts
    48 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Ok, I found my problem! I went into my default apps and under default home I found a live wallpaper was in there. i removed it and Haven't got the pop up since! Thank god I didn't have to do a restore.
  1. Bluetooth text messaging problems - Galaxy s4 and Nissan Sentra
    By mcalister7353 in forum AT&T Samsung Galaxy S4
    Last Post: 10-12-2014, 02:39 PM
  2. LG Optimus Extreme & Data problems
    By LakeofGlass in forum LG Optimus L
    Last Post: 05-26-2014, 12:56 PM
  3. Common Problems
    By PainFX in forum Samsung Galaxy S4
    Last Post: 05-24-2014, 10:59 PM
  4. The 'root' of the problem
    By suthern_man in forum General Help and How To
    Last Post: 05-24-2014, 10:09 PM
  5. Chrome Video Problem Moto X
    By CondellX in forum General Help and How To
    Last Post: 05-24-2014, 03:39 PM
