1. jada swan's Avatar
    Hello everyone.... I updated to 4.4.2 a while back and since then my INCOMING CALL NOTIFICATION POPUP doesn't work properly... It will "pop-up",but will not stay on the screen where I was before I got a call... I have yet to find a solution. Someone help.
    07-13-2014 08:08 PM
  2. H3aTeRzz's Avatar
    Did you do a factory reset after the update? I would highly recommend doing this if you have not. As has been mentioned in numerous other posts, its always good to do a factory reset after a major update, if you experience these types of issues after, whereas you didn't have them before. There are MANY factors in play when updating with a major update. Prior to reset, go into recovery mode and select the option to wipe cache...this will NOT delete your important data. If the problem still exists, then a factory reset would be recommended, hope this helps!
    Turn off the phone and remove the battery, then reinsert
    Press and hold the Volume Up key and Home key, then press and hold the Power key
    When it vibrates release the Power key
    The recovery menu should appear - release the other keys
    Navigate using the Volume keys to Wipe all cache (power key to select)
    Press the Power key to reboot
    07-15-2014 08:31 AM
  3. jada swan's Avatar
    Yes ive already done the factory reset...I just tried what u suggested,and it's still not working properly...I don't know what is going on.
    07-15-2014 01:08 PM
  4. H3aTeRzz's Avatar
    So it pops up giving you the option to answer or decline? And after you finish the call it won't go back to the screen it was on before you got the call? Sorry, I'm a bit confused as to what exactly the problem is I guess.
    07-15-2014 01:23 PM
  5. jada swan's Avatar
    I'm getting the popup, but when I answer (using speakerphone) the whole screen covers what I was doing....it's not supposed to do that.
    07-16-2014 02:11 PM
  6. H3aTeRzz's Avatar
    I recreated what you're saying by using my other phone, to call my note 3, and experienced the same thing your'e describing. I never had this function enabled, so its not something I missed or will miss. If this is indeed a bug, then perhaps the next update will address this issue. I would take it to a local best buy and ask a Samsung Rep.
    Have a great day!
    07-20-2014 02:50 PM
  1. I have call ,but my phone reboot
    By mfaridi in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 07-15-2014, 06:34 PM
  2. speeding the audio up on audio recordings!
    Last Post: 07-13-2014, 11:20 PM
  3. S3 not backing up with Kies
    Last Post: 07-13-2014, 11:12 PM
  4. HTC One M8 Emoji help
    By mitcheffinbridges in forum General Help and How To
    Last Post: 07-13-2014, 07:55 PM
  5. help knox please
    By bbmjack in forum Samsung Galaxy S5
    Last Post: 07-13-2014, 06:17 PM
