1. Andy847's Avatar
    Hi, just got a new Galaxy Note 3 and loving it so far. I bought an Otterbox Defender case which I love also, but I don't ever want to use the 3rd layer with the Belt Clip on it, except to protect the screen of the phone if it's dropped. I am not ever going to use it on my belt clip, so does anyone Know of a way to take the actual Clip off that layer without breaking it?
    I know I can get a replacement of the layer with the belt clip on Amazon, but would like to try to remove it if I get some help. Thanks in advance.
    08-11-2014 08:22 PM
  2. mchi5's Avatar
    If I'm reading you right you cannot just take the belt clip off with this third layer. I'm a bit confused but if you're talking about the holster, you don't need that anyways for protection. It's only if you want to use it as a belt clip.
    I hope I'm understating you correctly...
    sent from my Galaxy Note 3 via Tapatalk
    08-20-2014 08:28 PM
  3. Andy847's Avatar
    Yeah, it was the holster part with the clip. I ended up just removing the plastic screen protector from the defender and putting on an iloome flex tempered glass screen protector. It worked great on my note 2 with a different case, and now it works good on the otterbox defender case also with my note 3. Thanks for the reply though.
    Sent from my GT-N8013 using AC Forums mobile app
    mchi5 likes this.
    08-22-2014 01:08 AM
  4. mchi5's Avatar
    I did the same thing with my otterbox defender. Took the crappy plastic screen protector off, and I have the bodyguardz tempered glass screen protector on.
    08-22-2014 04:43 AM
  1. The Weather Channel App - battery drain
    By jmagid51 in forum General News & Discussion
    Last Post: 12-30-2014, 09:48 AM
  2. Replies: 8
    Last Post: 08-14-2014, 01:04 PM
  3. Replies: 1
    Last Post: 08-11-2014, 08:59 PM
  4. Replies: 1
    Last Post: 08-11-2014, 07:05 PM
