1. diggit's Avatar
    I leave my phone on charge overnight as I sleep but when I wake up, the phone is burning hot (55 degrees Celisius)
    I checked the "battery" section under settings and it said that my screen has been on for 3 hours straight..
    I realized it was because my phone would become fully charged and the notification "Fully charged, unplug charger" would come up and keep my screen on until I woke up..
    I've had my phone on auto time-out after 3 minutes of inactivity, and lock after 5mins.
    What should I do? How do I get rid of this notification/make the screen turn off after the notification comes up?
    05-09-2013 07:25 AM
  2. smooth4lyfe's Avatar
    Maybe shorten some of those times
    05-09-2013 11:47 AM
  3. Colonels's Avatar
    i was thinking that maybe some of the new sensors are a little wonky, so like your phone screen turns on from the notification and let's say something was laying across the screen like a bed sheet, wouldnt that set off the proximity and air view sensors to keep the phone on? or should the auto time out 3min override the air view sensor?
    05-10-2013 08:27 PM
  4. diggit's Avatar
    Wow sorry for the late reply, not used to this forum yet! But I don't think any of the sensors are keeping it up, I've turned everything off.. I've also shortened the time as smooth4lyfe said but that didn't help either
    Sent from my SAMSUNG-SGH-I337 using Android Central Forums
    05-13-2013 10:37 PM
  5. ibcnul8ter's Avatar
    mine gets hot after playing games. Almost too hot to make a call. check out the thermal picture, this is the front top.
    05-14-2013 03:36 PM
  6. ibcnul8ter's Avatar
    Reports are coming in from users of Samsungs new flagship Galaxy S4 that the device is getting a little too warm for comfort.
    It seems users of the Exynos Octa chipset variety are experiencing overheating issues, which is having a massive impact on battery life.
    One user even went as far tracking the temperature on his Galaxy S4; getting 27C when idle, 35C when browsing or checking email, and 40C when playing games!
    Some are theorising its to do with the location of the Exynos Processor, being too close to the radio and battery, compounding the heating problem. Whatever the cause is, most are recommending you turn off bluetooth and GPS (unless currently being used), dim the screen, and put the phone into power saving mode to restrict the processor.
    Hopefully Samsung will have a proper solution to this soon and well update this post if we hear anything.
    Source: XDA Developers Forum
    05-14-2013 03:37 PM
  7. NotJustAPhone's Avatar
    Subscribed.
    Sent from my Nexus 4
    05-14-2013 05:41 PM
  8. diggit's Avatar
    My phone gets hot pretty often. Apparently 40 is normal for the S4 but it's a little too hot in my hand.. Yes, for gaming it often hits the 40s but in idle it's around 25 and for light usage it's in its 30s. When I charge it goes up to 55 then restarts itself.
    05-14-2013 07:30 PM
  9. jagan164's Avatar
    My ATT- S4 Over heating - I am afraid my ears will burn..!
    Its been 7 days since I own this device. My S4 is heating up more when I turn on 4G (ATT). I am really afraid to make calls as I feel it is going to burn my ears..! On WIFI its getting hot when I am playing games. Not sure what do . When contacted Samsung they simply asking to Factory reset the phone and refusing to replace it.
    Please advice what to do now ?
    Thanks
    05-15-2013 10:41 AM
  10. Summest's Avatar
    I haven't found any way to disable the full charge notification on my S4. Support says to live with it. :-(
    06-02-2013 11:59 PM
  11. ladyesmiles's Avatar
    Download Du Battery Saver, free app in the app store. It will optimize your phone, tell you what to turn off, give you suggestions on how to keep it cool and help you charge your phone correctly. Never charge these S4's overnight even though some people say it's okay. When it is fully charged you are supposed to unplug it. You charge it when it is 20% or less on a fast charge to 80%, then a slow charge to 100%, then remove the charger. Phone will then not heat up and battery will last a very long time. I am getting 3 days on one charge with this little app. Turn off the app. when not in use. Also, always swipe down and turn off things your not using or get Llama app and set some conditions up that will auto do that for you. When I'm in the office, I turn of blue tooth, gps, data, etc. and use wifi, low screen brightness.I always have on the fun stuff, smart gestures, air view, S-voice, sync, and am still getting a great 3-day charge now. My phone does heat up when playing games. I don't think there is really any thing you can do about that.
    intazzz likes this.
    07-03-2013 09:54 AM
  12. BrandonF13's Avatar
    Hey, I know I'm late to the party but I found a solution.. well it worked for me.. Go to Settings, more settings, Developer Options and turn off "Stay awake".
    Screen wakes after charging. Can't stop it? ****** Bigelow seems to have found the fix and didn't realize it.
    07-26-2013 03:57 PM
  13. HalfHour's Avatar
    Also having a lot of trouble with over-heating on my Samsung GSM Galaxy Nexus 4.
    Seems to be chronic, with heat far in excess of "typical" much less "tolerable", coming from the processor region of the board (lower left of camera on underside).
    Mine has been aggravated by a flaky/dirty micro-USB jack. I've cleaned it up a couple times, but problem still occurs.
    Let me make it clear, the battery itself has not overheated, but it has been cooked by the chronic overheating from the phone internal circuitry. I have to go replace it.
    Why does Samsung push this under-tested, flawed kind of junk onto the market?
    08-12-2013 12:58 PM
  14. swimmaholic's Avatar
    This may not be selected but go ahead and look. Go to developer options and make the Stay Awake setting isnt checked.
    Posted via my HTC One or S4 using the Android Central App
    Lee Rogers51 and btswein like this.
    08-12-2013 04:39 PM
  15. Goldwin S's Avatar
    can we use that comes in the box or any other which is good and efficient to charge?
    Kindly suggest for S4..
    08-13-2013 07:27 AM
  16. jlopez1286's Avatar
    theres a setting on developer setting to turn off wake during charge... my phone dont heat up..
    08-16-2013 03:19 PM
  17. Kristopher Ulibarri's Avatar
    Yeah my phone is doing the same thing and it burned me and Verizon sent me a replacement and the first day I got it overheated again so they are sending me another but the replacements are all refurbished. So I don't recommend thus phone it will burn you.
    08-21-2013 12:39 AM
  18. Alex Davis2's Avatar
    It's in the developer options, which adore hidden now.
    1. Uncover the developer options by doing this: How to Enable the Hidden Developer Options on Your Samsung Galaxy S4 Samsung GS4 softModder
    2. Uncheck "Stay Awake"
    Now your phone will not stay lit up when it's fully charged.
    Lee Rogers51 likes this.
    09-24-2013 02:12 AM
  19. daddy69's Avatar
    How do I find if I have an Exynos processor?
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    09-29-2013 11:37 PM
  20. intazzz's Avatar
    where is developer setting?
    10-07-2013 11:45 PM
  21. adrianlew's Avatar
    Am I missing something or is this a Android Bug? Usually Developer option is usually hidden in a new phone. I also had the same problem, developer option was on and screen set to stay on while charging
    So when charged overnight my screen stayed on for several hours. Is this a bug or my phone was not 100% new?? Did it damage my screen? At least it was dimmed because it was dark...
    05-05-2014 07:12 AM
  22. pramod poudel's Avatar
    Helllo i have a problem with samsung duos.my phone speaks up saying that your battry is overheated.does anybody have any idea about this?????? I feel dhat my phone is going to brust any moment.
    06-18-2014 11:13 AM
  23. Aidan64's Avatar
    Take out the sd card. My phone used to overheat when it was being charged and the battery ran out within 4 hours. Took the sd card out and have no problems at all now.
    07-16-2014 07:55 AM
  24. HangOver1975's Avatar
    You can open dev. setting going to settings and tap on build nr. 7times. After this it should be available under settings menu.
    10-28-2015 04:46 PM
  1. Replies: 24
    Last Post: 09-24-2016, 02:30 PM
  2. "Fully charged unplug charger" message?
    By jmz768 in forum Verizon Galaxy S III
    Last Post: 12-07-2015, 11:50 AM
  3. How to turn off battery message "fully charged, unplug charger"
    By Schmidlapp84 in forum Samsung Galaxy S3
    Last Post: 10-04-2013, 02:22 AM
  4. I dont know what this notifcation icon is on my phone
    By gd6noob in forum myTouch 4G Rooting, ROMs, and Hacks
    Last Post: 09-27-2011, 04:02 PM
  5. Battery charged unplug charger wont go away
    By bellesc23 in forum Verizon Droid Charge
    Last Post: 08-07-2011, 09:30 AM
