1. LordAndroid's Avatar
    I was hoping with 4.4 kitkat the constant drain wouls of been resolved. Seems like this part of the OS went untouched. I charged my battery to 100% and in less than an hour i already lost 3% without even touching it. Im not setting such a high expectation but this is annoying Click image for larger version.
    Sent from my Awesome S4
    02-28-2014 07:56 PM
  2. UJ95x's Avatar
    I'd attribute some of that drain to the widgets and Google services. Both of which can be easily fixed, other than that, it doesn't seem like the OS is causing too much of a drain.
    Sent from my Galaxy S4 running SlimKat 4.4.2
    02-28-2014 08:07 PM
  3. LordAndroid's Avatar
    I have now changed my location settings to GPS only and now Google services has dropped from where it shows above down to 3 %. I'm very surprised to see this still exist on this version of the OS come on Google
    Sent from my 2014 Note 10.1
    02-28-2014 10:18 PM
  4. UJ95x's Avatar
    There are a few options for GPS. I think there is high accuracy, which uses the most battery, and more battery friendly mode. You can use that if you need location services on for some reason, but yeah, that uses a lot of battery and should be turned off when not in use. That helps a lot with the drain
    02-28-2014 10:21 PM
  5. LordAndroid's Avatar
    As long as. GOOGLE MAPSand other apps that utilize location settings continue to work I'll be happy i know Google now will only partially work. I wish this drain wasnt so harsh lol.
    02-28-2014 10:34 PM
  1. HTC media link HD problem after Kitkat
    By joel evo in forum HTC One M7
    Last Post: 04-04-2014, 10:56 AM
  2. New member from Cave Creek, Arizona
    By Jalopiejoe in forum Introductions
    Last Post: 03-21-2014, 03:44 AM
  3. Sell Note 2 now with 4.3 or worth more if 4.4 in a month(ish)
    By Matt Behnken in forum AT&T Galaxy Note 2
    Last Post: 03-02-2014, 11:57 AM
  4. Those who have upgraded from a Galaxy S3 to a quadcore phone?
    By Nemesis-X in forum General Help and How To
    Last Post: 02-28-2014, 10:13 PM
  5. note 3 with kitkat ota last night. (sprint)
    By slreno#WN in forum Android 4.4 KitKat
    Last Post: 02-28-2014, 02:42 PM
