1. Mithan Kitara's Avatar
    Hi guys, I am having some issues with my Girlfriends S4 (i337 AT&T Version).
    The issues I am having are below, but I want to know if you guys would recomend me upgrading it from 4.2.2 to some other ROM that may clear out these issues and what you would suggest me to upgrade it to?
    I want something that is STABLE, fairly close to the stock S4 Build or even the Stock Android GUI and easy to upgrade too.
    Or is the phone just screwed and I should look into replacing it? I have not upgraded the phone from 4.2.2 because as I understand it, doing that locks the bootloader and makes it a pain in the *** to root and upgrade.
    Issues she has:
    -When recording video, sometimes it wont record voice, sometimes it does. No idea why this is doing this.
    -Sometimes video's refuse to play, then it starts working again.
    -SD Card appears to disengage at times. Its Lexmar, maybe I need to get a Patriot like mine.
    -The phone just intermittantly disengages from the Cell Network or Wi-Fi network. She sees it mostly when she uses Viber. It runs well, then it just up and loses its connection then starts working well again
    -Has had a few issues where people dialing her just cant get to her, its as if the phone has been turned off, or she cant dial out on the network.
    -In certain cases repowering it corrects the issues for a while so I tell her to repower the phone once or twice a week.
    This is what her phone is running:
    SAMSUNG-SGH-I337
    4.2.2
    I337UCUAMDB
    JDQ39.I337UCUAMDB
    If this is not the correct place to ask these questions, please direct me to a better place, but I have found this forum to be an amazing resource with knowledgable people and I am not sure where to go
    03-01-2014 04:40 PM
  2. metle_geek's Avatar
    HE'LL NO DO NOT FREAKING UPGRADE
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    03-02-2014 09:04 AM
  3. metle_geek's Avatar
    I will buy it from you and send you a fully wiped kit kat official gs4 (as long as it's not cracked messed up screen scratched) with 4.2.2 I can root the heck out of it with 4.3 and up the boot loader can't be unlocked
    03-02-2014 09:05 AM
  4. metle_geek's Avatar
    Dude run a cyanogen mod and get the custom recovery with the lokidoki patch and honestly please get a 32 gig SanDisk never had a SanDisk card burn out it seems like she has corrupted data on the SD card back up your files on your PC and wipe the card
    03-02-2014 09:12 AM
  1. how to get videos on to computer??
    By Michelle Homes in forum Samsung Galaxy Ace
    Last Post: 03-04-2014, 02:52 PM
  2. Verizon LG G2: Speaker phone keeps enabling on its own
    By shadowsjc in forum Verizon LG G2
    Last Post: 03-04-2014, 02:42 PM
  3. Replies: 1
    Last Post: 03-02-2014, 04:26 PM
  4. Question from a new(ish) S4 owner
    By carp68 in forum AT&T Samsung Galaxy S4
    Last Post: 03-01-2014, 11:37 PM
  5. Games not working and missing on sd card. Help!!
    By executiveg in forum Samsung Galaxy Note 2
    Last Post: 03-01-2014, 06:18 PM
