Results 1 to 14 of 14
    mxcrowe's Avatar
    Posts
    Global Posts
    11 Global Posts
    Default Stuck at Odin Mode - ROM will not boot - Need some initial guidance
    I'm trying to fix a phone for a friend, so it's not my handset and I'm not that familiar with the GS4, -- hoping I can get some pointers in the right direction here.
    Apparently, he tried to install a custom ROM and perhaps did so over his stock ROM, so the phone just boots to the white screen with the AT&T symbol. It produces various alert noises and seems to be trying to communicate with the towers (I can hear the interference on my PC speakers), but it never changes from that white screen and requires a battery pull to turn it off.
    If I boot into recovery (VolUp+Home key+Power button), it gives me the following:
    Could not do a normal boot.
    Odin Mode.
    SGH-I337
    Binary: Samsung Official
    System Status: Custom
    Knox Kernel Lock: 0x0
    Knox Warranty Void: 0x0
    CSB-Config-LSB: 0x30
    Write protection: enable
    eMMC burst mode enabled
    Unfortunately, I cannot get it to do anything from there. If I start with VolDown+Home+Power, it seems to launch Odin successfully. If I cancel to boot at that point, I'm back to the white AT&T screen.
    Hopefully, somebody here can tell me what steps to take to get this back to stock (or whatever other alternative there might be). I just didn't want to dive in and make things worse without getting some guidance first. Can anyone provide any pointers about how to proceed with this or good threads to look at to help unscrew things?
    He tells me it had 4.3 on there when the problem happened and Odin was version 3.07. The phone had been rooted. I don't know how to get any other version information out of the system in the state it is currently in.
  2. #2
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,711 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Default Re: Stuck at Odin Mode - ROM will not boot - Need some initial guidance
    Quote Originally Posted by mxcrowe View Post
    Odin Mode.
    SGH-I337
    You are probably going to have to flash a stock ROM all over again. You can get them on Sammobile.
    mxcrowe's Avatar
    Posts
    Global Posts
    11 Global Posts
    Yes, that is what I had to do. Pretty much reflashed everything back to stock. All is now back in working order.
    I used the method described here: | ★ MK2 ★ FULL ODIN TAR FILES ★ MK2 ★ | ★ UNBRICKED ★ Feb.06.2014 ★ | - xda-developers
  4. #4
    Yea run odin and flash the stock.tar it would help to know what android version he had before so we know what boot loader we are dealing with if he had 4.3 and tryed to run twrp or cwm thats your smoking gun as this boot loader is locked and can only be safe strapped (boot strap recovery) if he didnt do any of the ota updates and luckily still has 4.2.2 he needs to reflash the recovery with the lokidoki tool
    must have unlocked boot loaders!!
    mxcrowe's Avatar
    Posts
    Global Posts
    11 Global Posts
    Also correct. Trying to install/flash with TWRP was the problem, most likely. Yes, as per the OP, he was (and is) at 4.3. I did flash recovery, as well as everything else to get it back to stock functionality.
    metle_geek likes this.
  6. #6
    I have the same problem I am stuck at ODIN mode, I tried several times to root but filed all methods. I got OTA update to NC1 I could avoided when I noticed was already done. Then I try to downgrade from NC1 to MK2 then all got screw. Ive been trying to ODIN firmware with no results. My screen looks like this
    Odin Mode.
    SGH-I337
    System Status: Official
    Please help!!!!
  7. #7
    Quote Originally Posted by Nestor Rob View Post
    Odin Mode.
    SGH-I337
    Please help!!!!
    No you need to down grade from nc1 to mdl to mk2 in that order you simply can't jump and miss one are you on xda and using the venom magic tool?? It works like this you have to go from mc1 mdl to mk2 once on mk2 boot use safe root to root flash safe strap 3.72 then put it into odin mode then you flash the mdl and boot script updater (if needed for that rom) once you flashed a new kit kat rom you boot normal uninstall safe strap 3.71 then install 3.72 as 3.71 will not mount a kit kat system partition and 3.72 is built for kit kat they are not interchangeable so please follow instructions
    http://forum.xda-developers.com/show....php?t=2680868
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
  8. #8
    OK 4.3 if he wants a rooted kit kat go here and follow the instructions they are simple and it worked for me on the first try http://forum.xda-developers.com/show....php?t=2680868
    Other than that he will not have a custom kit kat rom sorry no AOSP roms as they need a different kernel and with a locked boot loader you can't get it it will simply boot loop as it did or boot into nothing http://forum.xda-developers.com/show....php?t=2680868
  9. #9
    i have a samsung galaxy S4 verizon i545 i tried to flash the firmware using Odin3 V.3.09 but it gave me an error since then my phone doesnt boot when it turns on it goes to Odin Mode and in the bottom it says "Firmware Upgrade encountered an issue connect to samsung kies for recovery and try again and nothing more it cant even boot into recovery mode.
  10. #10
    Sorry that magic tool is for at&t only I'm not too keen on Verizon your going to have to check your device threads
    Garvin6600 likes this.
  11. #11
    download samsung kies.. and also download usb driver for your phone model... after that connect your phone with lappy via usb. open kies and click on emergency recovery
  12. #12
    Attempted to root phone but got boot up error:
    RECOVERY BOOTING...
    RECOVERY IS NOT SEANDROID ENFORCING
    Set Warranty Bit: recovery
    Fixed it by taking battery out and pressing VOLUME DOWN and POWER (don't need HOME), this reset it and everything back to how it was (thank f*ck for that!!)
    So lucky as thought I had wrecked it.
  13. #13
    I don't know where you found the advice to try this method, but it worked for me. Thank God. I thought my phone had become a brick when it went into a loop and showed the Android icon and a message that it was downloading and "do not disconnect the target." Thanks for sharing!
  14. #14
    Quote Originally Posted by gwynwjones View Post
    RECOVERY BOOTING...
    Omg thank you. It got my phone up and running again. I bought a gs4 verizon phone and guess it has a custom rom. Went to update it and it was stuck in a mode that said downloading. Thanks again
  1. Galaxy S3 I9300: Not registered on network issue
    By wildechap in forum Samsung Galaxy S3 I9300
    Last Post: 11-04-2014, 04:25 AM
  2. Why my note 3 does not respond well in mornings?
    By Myat K-Phoenix in forum Samsung Galaxy Note 3
    Last Post: 03-21-2014, 04:55 PM
  3. Excruciatingly slow browsing on WIFI but not 3G
    By MartinStaceyUK in forum Android 4.4 KitKat
    Last Post: 03-21-2014, 04:22 PM
  4. AT&T Note 2 SGH-i1317 stuck in boot loop
    By Bradley Ferguson in forum AT&T Galaxy Note 2
    Last Post: 03-21-2014, 02:32 PM
