Results 1 to 6 of 6
    Default Samsung Galaxy S4 Wifi problems
    My S4 has been having some issues lately, WI FI will turn off by itself, it won't connect to connections (it will saved them) unless I restart the phone, please help me, what can I do to fix this problem.
    Lheurung likes this.
  2. #2
    Default Re: Samsung Galaxy S4 Wifi problems
    Quote Originally Posted by thefreak75 View Post
    Is it stock and did you take the kit kat update??
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
    did the kitkat update,why? the problem started not too long ago
  4. #4
    I am having the same problem. My wifi will turn itself off with no notification, in the middle of a solid reliable connection. It also won't remember my home network password but connects to my work wifi automatically. Baffled.
  5. #5
    You got a bad flash you have to re flash the modem you got remnants of the old kernel in there and old modem so what you need is a clean flash hopefully you won't loose anything tho if you want to stay stock take it to a best buy and get the Samsung experience rep
  6. #6
    Since my last s4 update my wi-fi turned off with no notification; used all my mobile data in four days. Is this a "problem" or simply that one needs to re-check settings?
  1. Replies: 16
    Last Post: 11-24-2016, 01:07 PM
  2. Replies: 8
    Last Post: 11-25-2015, 02:13 PM
  3. Galaxy s3 kitkat
    By sakdgr8 in forum Samsung Galaxy S3 I9300
    Last Post: 04-07-2014, 10:15 PM
  4. s4 mini speaker only makes around half the volume
    By elias m in forum Samsung Galaxy S4 Mini
    Last Post: 04-07-2014, 10:25 AM
  5. Samsung Galaxy S4 & Galaxy Note 3 SIM Lock feature
    By faizanrizvi in forum General Help and How To
    Last Post: 04-07-2014, 06:36 AM
