Results 1 to 6 of 6
    Default HELP!! att i337 s4 phone calls not working well
    Hi all,
    I have a galaxy s4 i337 from att. I unlocked it and am running it on simplemobile.. the phone cuts out mid calls, sometimes it doesnt dial out at all, when I answer sometimes the phone stays on the screen where you can either reject the call or accept it but doesnt actually do either.. this is becoming a major issue, to the point I wish I didnt give away my galaxy s2..at least that one functioned properly.
    I also am still stuck on 4.2 version of android, and never got new versions pushed.. I really need my phone to work properly- im at the point where I just want to throw it at a wall whenever it gives me issues..
    Ive also tried changing the gsm/cdma settings from lte/gsm auto to just gsm.. no luck..
    Please help!!
  2. Thread Author  Thread Author    #2
    Default Re: HELP!! att i337 s4 phone calls not working well
    Anyone...any o ne at all willing to help??
    I cant even answer regular calls anymore...
  3. #3
    wizzrah's Avatar
    Posts
    Global Posts
    4,726 Global Posts
    Carrier
    Kitkat
    Hello. Sounds like a problem with the carrier. It could also be a APN issue.
    Wizzrah | AT&T HTC One XL | Tapatalk
  4. #4
    Yea I was thinking the same thing also are you sure simple mobile and at&t run the same gsm bands?? Also check your apn not all Sims automatically set them so if it's still in default at&t it's guaranteed to screw up unless they run the same bands and your going to have to change it anyway for mobile data
    Sent from my SAMSUNG-SGH-I337 using AC Forums mobile app
  5. #5
    From what I can find on simple mobile.com you need to set your apn to a tmobile apn as they run off the t mobile network and your not going to get LTE as they are on the hspa+
  6. #6
    Please do your research before switching
  1. Replies: 3
    Last Post: 09-05-2014, 06:09 PM
  2. Not registered on network
    By HarryDevice in forum Samsung Galaxy S3 I9300
    Last Post: 04-25-2014, 03:13 AM
  3. Verizon M8 not receiving calls
    By mhunter6378 in forum HTC One M8
    Last Post: 04-24-2014, 12:13 PM
  4. MMS text messages not downloading to Galaxy SII phone.
    By Gary Casimir in forum Samsung Galaxy S II
    Last Post: 04-24-2014, 10:07 AM
