Results 1 to 14 of 14
    Default Help with using Kies and Infuse
    I just bought the Samsung Infuse from At&t. From googling around, I found out that I could use Kies to sync contacts, etc. I have downloaded Kies 2.0 from the Samsung UK website. The installation went fine. I have windows XP on my PC. But when I plug the phone to my computer. It gives me an error message saying that the phone is not supported. Please help!! Thanks.
  2. #2
    Default Re: Help with using Kies and Infuse
    Apparently Kies is only supported for Macs at this time. I used it successfully on my Mac.
    Egídio
    Austin, TX
    Thanked by:
    Flores
  3. #3
    I get the same error message. Samsung is notorious for their poor syncing software. There is software called Android Sync for the phone and windows it works ok and there is a free version. But I gave up on syncing with outlook an just use gmail for now.
    Thanked by:
    Flores
  4. #4
    chestvrg's Avatar
    Posts
    Global Posts
    1,031 Global Posts
    ROM
    ICS
    Default
    Also Kies is only being supoorted for the int'l versions of the Galaxy S or SII (GT-i9100 the one I have) or the GT-i9000M/T (the first gen. Of Galaxy S), but not the carrier version of Samsung smarphones such as the infuse 4G unless I'm wrong. This is very pitiful because HTC Sync software allows just about any HTC device running android to sync their PIM, music and pictures.
    I am succesfully able to sync my GSII with kies using Outlook, b/c I have an int'l Galaxy SII fortunately. I use windows 7 operating system also. I'm able to sync all of my contacts (168 entries), notes (67 entries), calendar entries (over 135 entries), my music and pictures. For some weird reason Kies will not sync my itune playlists, so I resorted to iSync software for syncing all of my music library and playlists. As far as contacts, calendar entries and notes syncing with Outlook, kies works perfectly (I'm very happy)
    I hope this helps.
    Sent from my GT-I9100
    my Galaxy S2 GT-I9100
    Thanked by:
    Flores
  5. #5
    For some reason Samsung has disabled Kies on their US phones. However, there are drivers in Kies that will help you use other 3rd party synching software. You can use MyPhoneExplorer, it is a free app that works very well. I use it and after setting it up properly, I can now sync outlook contacts and calendar with my phone.
    Much easier and better than the Microsoft solution, which is to do it via Hotmail.
    Hope this helps.
    Thanked by:
    Flores
  6. #6
    If backing up is what you're after, you can also check out . The free version includes some backup and also has a where's my droid feature.
    Egídio
    Austin, TX
  7. #7
    aapold's Avatar
    Posts
    Global Posts
    670 Global Posts
    I just sync everything via exchange. But that only works if you have exchange...
  8. #8
    ponyexpress1's Avatar
    Posts
    ROM
    Gtab: Vegan Gingeredition
    You can google sgh i997 support and go to the Samsung website. There you can download the owner's manual and/or the usb driver software for Windows. I did it 30 minutes ago and it works fine.( based on what I read it is Kies Mini)
  9. #9
    chestvrg's Avatar
    Posts
    Global Posts
    1,031 Global Posts
    ROM
    ICS
    Default
    Samsung needs to really fix this and allow all US carrier phones to access Kies just like they do with the Int'l version.
  10. Thread Author  Thread Author    #10
    Thanks for all of your valuable feedback! Looks like maybe I am out of luck with using Kies in the US.
    Has anyone tried the Samsung PC Studio solution? Does it work with the US version of Infuse?
  11. #11
    Posts
    ROM
    Flores, go here. chestvrg, nothing for your phone yet.
  12. #12
    chestvrg's Avatar
    Posts
    Global Posts
    1,031 Global Posts
    ROM
    ICS
    Default
    Quote Originally Posted by ponyexpress1 View Post
    Thank you, but I have the Int'l version GT-I9100 Galaxy SII. My problem is that I can't activate my Samsung social hub portal.
    At the samsung social website: it doesn't allow me to register my IMEI. It tells me my IMEI is no accpeted.
  13. #13
    Quote Originally Posted by Flores View Post
    Did you read any of the reviews on the PC Studio? It doesn't sound too promising. Sadly!
  14. #14
    The only PC studio that actually worked well was 1.2b. It even synced with outlook quite well. And yes I did try to connect the Infuse and it did no work.
