Results 1 to 10 of 10
    Default Did I ruin my battery?
    About a week and half ago I was using my Infuse with the Navigation dock while plugged in. I hadn't looked at the phone in awhile and I picked it up and there was a symbol of a battery with a warning sign and a temperature gauge on it, then it went off. Every since this it seems like my battery doesnt last very long. Before that I could get what I would call decent usage, almost all day with moderate use. Now if I use it some during the day (few webpages, facebook, text, etc..) i get nothing. Today I unplugged it at 7 am and now its 4:45 pm and I'm am showing 23% with 3 hrs 39 mins left (via Juice Plotter). Is there a way to check the health of the battery? Did I ruin it?
  2. #2
    Default Re: Did I ruin my battery?
    i would be more concerned if you hurt your phone vs your battery. It sounds like you way overheated the cpu.
    Quote Originally Posted by achysklic View Post
    Is there any signs that will tell me if that happened or any way to check?
  4. #4
    Kevin O'Quinn's Avatar
    Posts
    Global Posts
    7,659 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by slbe1892 View Post
    Start with the battery. It's cheaper.
    Sent from my SAMSUNG-SGH-I997 using Tapatalk
    Forum Rules & Guidelines -- CLICK HERE
    I'm an NVIDIA Tegra Champ. Here's what that means. It means that from time to time I might receive products and/or services from NVIDIA to evaluate them and provide feedback to NVIDIA and you, our valuable members. What this does NOT mean is that my opinion will be biased. Any opinion that I express here and elsewhere are solely based on my personal preference and any relevant expertise that I may/may not have on the subject matter.
  5. #5
    I would suggest to watch your phone over the next few days to test it out,and that's great that you already have JuicePlotter to monitor it.Try to see what heavy,moderate,and low usage does to the phone and change some of the settings in your phone to help more with battery life.If you feel like it isn't performing to what you think is good,then look at getting a newer one.
  6. #6
    goelz83's Avatar
    Posts
    Global Posts
    156 Global Posts
    The battery is under warranty from AT&T. Call the warranty department at 1-800-801-1101 and they will send you a replacement.
    Well I just sent my Infuse to Samsung under warranty. I hope it goes well and they figure it out.
  8. Thread Author  Thread Author    #8
    Got my phone back yesterday and wanted to see if anyone here could tell me if the problem they fixed was legit. It had a paper with my phone that said "SW/PRL wouldnt update". The solution said "sw updated, passed all functionality tests, prl updated".....Would any of that have to do with my battery not holding a charge?
  9. #9
    Same thing happened to my wifes phone, but hers wont charge it just shut off. We just had our phones for a a month, so we went back to costco and they replaced it with a new one,they said hers was a lemon. hmmmm??? Now im trying to test mine if it does the same thing.
  10. #10
    Posts
    Global Posts
    7,659 Global Posts
    ROM
    Stock
    Default
    No
