1. keelon.ellis's Avatar
    Ok...so I go into the grocery store and everything looked like it was supposed to...using the go launcher...I come out and look at it again...back to the touchwiz stock screen...and says safe mode at the bottom..I would like to know what causes this so I can prevent it from happening again...and also how to get it off of safe mode
    09-23-2011 07:05 PM
  2. 631735's Avatar
    if you're on a custom rom, could be a bad install. try reflashing. if on stock, could be a new app borking it. i've never seen safe mode but i'd assume rebooting the phone would be fine? (haha have you tried turning it off and on again -IT Crowd)
    keelon.ellis likes this.
    09-23-2011 08:52 PM
  3. keelon.ellis's Avatar
    It just needed to be rebooted...never figured out what caused it tho...its been working fine now tho...thanks!
    09-25-2011 01:11 PM
  4. onofre56's Avatar
    have any of you figured out why it entered safe mode on its own? Because mine just did and i want to know what caused it.
    01-16-2012 02:05 AM
  5. sassyred64's Avatar
    Same thing happened to me, rebooted it worked thank you
    01-18-2012 09:12 AM
