Hi All,
I have been having a couple of problems with my Samsung Infuse which I am using in UAE but is fully unlocked,
1. I do not get SMS delivery notifications and in searching the settings cant find any. When I put the SIM card in another phone, it shows that the network has activated the same already however with Infuse it does not work.
2. Second issue is that when I send an SMS in local format (local number only) or with plus format (+followed by country code...etc), the SMS shows message failed. Sometimes it sends and sometimes it does not send. Any ideas to correct the same. Again when I shift the SIM card to a new phone, it all works fine.
3. The GPS keeps taking hours and still does not lock on inspite of the fact that I am in an open place where Samsung Galaxy S2 quickly picksup.
I have had no successes on other forums so any help will be appreciated.
Cheers
Pathfinder
Cheers
Pathfinder
