Results 1 to 3 of 3
    Default Low Memory? Theres no way already!
    for some reason my phone is telling me my memory is too low to download anymore apps...but there's no way....I don't have very many apps downloaded...any way to fix this....also if I rooted my phone and its not working correctly and I can't get the root off...if I told att my phone was stolen do they send me another one for free
    OS History
    Palm OS, Windows Mobile 6, Blackberry 4.5, 5, and 6, and WebOS...no contest...Android Wins!
  2. #2
    Default Re: Low Memory? Theres no way already!
    Your phone is ok,and the problem is coming from the android market,which the way to fix this is to go into settings,manage apps,look for market.Once you tapped market,just uninstall the updates,which will take you back to the old market place,but don't worry cause it'll come back to the new in a few.Uninstalling the maket is just a temp fix right now till a newer update fixes this problem.
    Thanked by:
  3. #3
    Thanks for the tip. I was having low memory issues when using paypal check capture and this "fixed" it for now. To bad one can not remove the bloatware without rooting, which I will try on my droid charge once I am eligible for an upgrade. Then if I brick it I can get a better phone, if there is such a thing.
    Larry
