Results 1 to 3 of 3
    Default Battery Problems. Help!!!!
    I have had my Samsung Infuse for about a year now and it has worked fine until the past few days. Yesterday my phone would turn off randomly and then turn on for a few minutes and then do the same thing again. Now my phone just turns on for a few seconds and the Samsung logo turns on and then it shuts off and keeps on Doing that. Yesterday when it would turn off after a few minutes the battery was at 87 percent and after turning off and on it was 15 percent. If anyone could help that would be appreciated.
  2. #2
    Cranky's Avatar
    Professional
    Posts
    Global Posts
    242 Global Posts
    ROM
    JellyBean 4.1.1
    Default Re: Battery Problems. Help!!!!
    Sounds like a bad battery. Either borrow someone else's battery for the Infuse to test, or go on Amazon and buy a new one. They're pretty cheap.
    Cranky...
    Ported JW8 SAUROM Project / Galaxy Blue - Theme -
    Is Anybody Out There?
  3. #3
    I have the same problem. I tried a different battery but the problem didn't go away until AT&T replaced the phone. Any other ideas?
