Results 1 to 7 of 7
- 07-29-2012, 01:56 PM
Thread Author #1
GO SMS Pro Help!
I have a DIY theme that i downloaded. I installed custom fonts and tweaked it a bit. I need help figuring out why every time i turn off my phone, or reboot it, my customized GO SMS settings go back to the default settings (as if i had just downloaded the app for the first time). Heres the lay out of my phone.. just so you know what I have tried. My phone is rooted.. I have titanium back up. I've backed up the app plenty of times with its new settings. Didn't work. I backed up the app in it own settings under basic settings/ back up and restore ... Didn't work. I saved my "DIY customized" under a different name.. didn't work [yet this enables me to go to appearance settings every time it resets, and switch the default back to my customized, so i don't have to go back through and re-tweak it every time] ... Im not really sure what else to do, if you know, please help
- 07-29-2012, 03:42 PM #2Cranky...
Ported JW8 SAUROM Project / Galaxy Blue - Theme -
Is Anybody Out There? - 11-20-2012, 04:00 PM #3
- 01-05-2013, 05:16 AM #4
Re: GO SMS Pro Help!
please HELP! whenever i send sms. the receiver only receives almost half of the sms. meaning, the sms is being cut. i dont know why. im using go sms pro. because i cant use the stock messaging because it automatically converts sms to mms. help please. what to do .
- 01-12-2013, 10:37 AM #5Cranky...
Is Anybody Out There? - 01-13-2013, 08:42 AM #6
- 01-23-2013, 06:10 AM #7
Reply
