I have had this issue before, and have been able to fix it. Something is different this time. I had auto-retrieve turned on for mms. It is still coming up with the manual download button. When I tap that it thinks for a bit, then tells me "Download of message from -Contact- unsuccessful". I have packet data turned on, I have auto-retrieve turned off and on and off and on. It doesn't matter, it doesn't work in either off or on mode. I tried using GoSMS Pro instead, that didn't work.
The crazy thing is, this has happened to me twice before. Both times I have been able to fix it with the solutions I just listed. For some reason, nothing is working this time.
I can also send pictures just fine. Only receiving seems to be an issue.
Help please.
Help please.
